Amp turns off after less than a second
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8185
Printed Date: March 29, 2026 at 9:05 AM
Topic: Amp turns off after less than a second
Posted By: prodigenic
Subject: Amp turns off after less than a second
Date Posted: January 15, 2003 at 5:54 PM
Thanks for reading, I have a 900watt amp which turns on when I turn on my head unit(I can tell its on because of its light strip), but it only stays on for a second before fading away.
My ground is fine, i have a 4ga. cable from the battery.
Could my battery just be too old?(exide with only 525 cca)
dk
Posted By: brianh
Date Posted: January 15, 2003 at 7:32 PM
Sounds like you might have a bad remote turn on output.  Try jumping 12 volts from the 12 volt wire on the amp to the remote turn on terminal.  If it comes on and stays on I would say your turn on lead is bad.  If that is the case you will need to hook the turn on lead to your switched ignition wire in your vehicle.  That way it will turn on and off with the vehicle.  Good luck with it.  Brian
Posted By: Velocity Motors
Date Posted: January 16, 2003 at 10:03 AM
Make sure that you remove the other remote turn on lead prior to jumping the two terminals. If there is a short and you jumper the two terminals, you could fry the amp by forcing it to stay on with the jumper wire.
Date Posted: January 16, 2003 at 7:36 PM
thanks for your help
i found out my ground was too weak
