power & speaker wires down seperate sides?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=81888
Printed Date: May 12, 2026 at 10:55 PM
Topic: power & speaker wires down seperate sides?
Posted By: yohinan
Subject: power & speaker wires down seperate sides?
Date Posted: August 21, 2006 at 9:47 PM
Is it still common practice to run your power wires and speaker wires down seperate sides of the vehicle or has wiring technology gotten to the point that this is not of a concern anymore (or can this only be done with shielded wire). As you can tell it's been many years since I have done car audio but I am getting back into it. For those that were wondering yes i did a few searches with no results so hence the reason for this post. TIA for the help
Posted By: austincustoms
Date Posted: August 21, 2006 at 9:56 PM
even with shielded wires, it's a good idea to go down sepereate sides, especially with high power systems.
Posted By: Velocity Motors
Date Posted: August 21, 2006 at 10:04 PM
As long as you run your RCA's separate of any power wires you should be fine. Running your power & speaker wires is OK.
------------- Jeff
