double din, 98 crown victoria
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82009
Printed Date: May 12, 2026 at 1:12 AM
Topic: double din, 98 crown victoria
Posted By: oscarnl86
Subject: double din, 98 crown victoria
Date Posted: August 24, 2006 at 4:15 PM
hey guys simple question i went to the 2006 metra aplication guide and for the 98 crown victoria under double din it says n/a does that mean that car is not a double din or how can you find out if it actualy is a double din??
------------- i know some stuff and what i dont know ill make it up feel free to ask
Posted By: cntrylvr79
Date Posted: August 24, 2006 at 4:51 PM
You can fit a double din in a 98 crown vic, however it will take a fair amount of modification to the rear of the dash to get it to sit in properly.
------------- Cause I'm So white and nerdy...
First Class Certi-fried installer
Date Posted: August 24, 2006 at 5:14 PM
ok thanks man ------------- i know some stuff and what i dont know ill make it up feel free to ask
Posted By: auex
Date Posted: August 24, 2006 at 11:34 PM
Metra makes a kit that makes ford dd easy.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Date Posted: August 25, 2006 at 4:42 AM
The problem with the car is the top of the radio cavity slopes down in such a way unless you want to mount the radio out about an inch or so you have to go in an start cutting.
Date Posted: August 25, 2006 at 9:23 AM
apreciate the input guys ------------- i know some stuff and what i dont know ill make it up feel free to ask
