tiburon stock battery problems
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82416
Printed Date: April 18, 2026 at 10:56 AM
Topic: tiburon stock battery problems
Posted By: hcabrera
Subject: tiburon stock battery problems
Date Posted: September 03, 2006 at 4:04 AM
ok heres the story i have (2) memphis 250d (1) memphis 55x4 (2) memphis 12" pr subs epicenter line driver memphis paremetric eq kenwood hu. ok my tiburon is an 06 with a stock battery and it has died on me. so i ordered a Kinetik hc800 to supply my needs do you think this battery will make a diffence in voltage and will it make my system work more efficent? also can this battery keep up with my demand's? i am worried that the alternator will be damaged due to this load or should it be ok once i change the battery? also i am thinking about getting a digital voltage meter on my battery terminal what is the correct voltage that my system should be running at? thank's!
Posted By: stevdart
Date Posted: September 03, 2006 at 5:49 AM
You're asking a bit prematurely.  Get your new battery installed, and upgrade the Big 3 wiring.  Spend some time double-checking gain settings and basic setup.  Then...run your system in the evening while driving normally with the lights on.  You'll know if the alternator isn't keeping up with the load.  You don't need a digital readout to tell you this.
Posted By: supradude
Date Posted: September 03, 2006 at 11:22 AM
Stevdart hit the nail on the head with the "upgrade the big 3" statement. That might the only thing you'll have to do.
'85 Toy
Posted By: killer sonata
Date Posted: September 03, 2006 at 1:55 PM
BIG 3 I have an 03 sonata and noticed a big change in the big 3. hyundais such for upgrading the alternator. Ive already looked into it. You basically have the pull the engine to get ti the alt and no one sells a bolt on upgrade so you either have to have it rewound for higher output of have a custom built one made.
Posted By: hcabrera
Date Posted: September 03, 2006 at 4:52 PM
ok the big three ok. will this void any of my warranty on my hyundai? also is there a link or a post that you have where it tells you step by step exactly what you need to do for the big three? thanks im sorry for the big three questions im a rookie. thnank's for the advice guys
Date Posted: September 03, 2006 at 7:02 PM
Look under "featured forum topics" / "how to upgrade the big 3".
'85 Toy
Date Posted: September 04, 2006 at 3:34 PM
for the warantee question, google the magnusson moss warantee act. basically it states that if they try to blame something that went wrong on something you did, they have to prove it.
