2006 sonata, avic d1, am reception
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82539
Printed Date: April 09, 2026 at 5:24 AM
Topic: 2006 sonata, avic d1, am reception
Posted By: mistahiggs
Subject: 2006 sonata, avic d1, am reception
Date Posted: September 06, 2006 at 1:44 PM
Recently installer a pioneer avicd1 in a 2006 hyundai sonata, and there is horrible AM reception, plus loud popping through the speakers when turning on the lights or depressing the break.  Tried isolators and regrounding the system, still no luck.  Has anyone encountered this before?
matt
Posted By: sparkie
Date Posted: September 06, 2006 at 7:00 PM
Try unplugging the antenna from your radio. See if you still have any noise on AM from these items. I realize that you won't get any reception, but you need to determine if the noise is creeping into the system or through the ground or other wiring. Use a digital ohm meter and measure the resistances in the antenna cable. The outer shield of the antenna should have less than 0.5 ohms resistance to ground. You should have less than 0.5 ohms resistance from the center lead of the antenna at the radio to the antenna mast. There should be no continuitity between the center conductor and the shield. It is also possible that these cars may use an amplified antenna of sorts. It may have to be powered in some fashion. Make sure that your radio has a good ground to the chassis too. Don't use the factory ground wire in the radio harness.
sparky
