speaker polarity problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=82591
Printed Date: May 04, 2026 at 5:22 PM
Topic: speaker polarity problem
Posted By: lukesdp
Subject: speaker polarity problem
Date Posted: September 07, 2006 at 4:17 PM
hi, im putting in some alpine speakers in my 1999 durango. ih ave downloaded the speaker wire diagram for my vehicle from this site, and it does ot match with my car. i connected the speakers with the best of my knowledge, but now im afraid to give em a try. whats the worst that could happen?? i have 4x 50rms alpines on a 4x50rms kenwood reciever. what will happen if i did wire them wrong? looking for a quick response, thanks.  :D
Posted By: xscash
Date Posted: September 07, 2006 at 4:31 PM
the bass would be off. one speaker would cancel the other out. here is what i have
#1946: 1999 DODGE DURANGO 4DR SUV
 Audio/Mobile Video
 WIRE  COLOR  POLARITY  LOCATION
 Battery  RED / BLUE  (+)  RADIO HARNESS
 Accesory  RED / WHITE  (+)  RADIO HARNESS
 Ground  N/A
 Illumination  BLACK / YELLOW  (+)  RADIO HARNESS
 Dimmer  ORANGE  (+)  RADIO HARNESS
 Amp Turn On  DARK GREEN/ RED  (+)  RADIO HARNESS
 LF Speaker (+)  DARK GREEN
 LF Speaker (-)  BROWN / RED
 RF Speaker (+)  BROWN / YELLOW
 RF Speaker (-)  BROWN / LIGHT BLUE
 LR Speaker (+)  WHITE
 LR Speaker (-)  DARK BLUE/RED
 RR Speaker (+)  BROWN / WHITE
 RR Speaker (-)  BROWN / ORANGE
 Amp Location  PASS KICK PANEL
 Radio Security  YES
expandable sound
south of boston
Posted By: lukesdp
Date Posted: September 07, 2006 at 4:35 PM
well, the thing is. i have the 4 passanger version, there is no amp. i think thats why those charts dont match with my car. for example, my Rear Right speaker has two wires, blue/white and blue/orange. so my guess was that white was the negative, as thats the standart. would i be able to notice the sound differance, so i could flip the cables?
Posted By: killer sonata
Date Posted: September 07, 2006 at 5:40 PM
time to whip out the old DMM and figure it out the hard way eh?
Posted By: KarTuneMan
Date Posted: September 07, 2006 at 8:15 PM
https://www.installdr.com/Harnesses/DCP-Wiring.pdf
see if this helps...I don't know for sure. The only wires that CANNOT be hooked up incorectly are costant, switched, and illumination (dimmer) Get these figured out first with your meter.
Posted By: lukesdp
well all fixed, i figured out that my multimeter can tell positive/negative volt; aka polarity. so it turned out to be simple, thanks for the help.
Posted By: coppellstereo
Date Posted: September 07, 2006 at 10:53 PM
if the signal is simply going from the HU through the existing factory wiring it should be simple. The white striped wires are positive. Any black stripe is negative
They would still play, but some speakers could be 'out of phase' from each other.
This means that when on speaker moves 'forward' the other speaker moves 'backwards'
