Choosing the Right Amp Wiring Kit
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83144
Printed Date: May 12, 2026 at 10:30 PM
Topic: Choosing the Right Amp Wiring Kit
Posted By: anton1606
Subject: Choosing the Right Amp Wiring Kit
Date Posted: September 20, 2006 at 2:40 PM
Hey I finaly got my deck to work. Now I just wanna know what type of Battery wire Ill need, ground wire and some info on those RCP wires to hook up the amp. ill give u the info on my stuff below.
Amp. Power Acoustik LT980-2, i believe its 1950watts.
Subs are X-Plodes, 2 of them in a box, each 10" and each is 1100watts @ peak power.
If anyone can just tell me what gauge the ground and battery wires shud be for the amp id appreciate it.
AAA
Posted By: xtremej
Date Posted: September 20, 2006 at 4:23 PM
Or go to your local audio shop and buy bulk rca's, usually much cheaper. Never had any issues runnning them with the subs. For power wire and ground it depends on the length of the wire run, what are you installing this equipment in? And rememeber a ground is just as important as the power it should always be the same size or larger than the power wire...
