How does a factory Remote wire work
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83204
Printed Date: March 29, 2026 at 6:00 PM
Topic: How does a factory Remote wire work
Posted By: sub-zero
Subject: How does a factory Remote wire work
Date Posted: September 21, 2006 at 9:56 PM
i would like to know how an automobile remote turn on system work. I am curious because i want wire up my car stereo equipment in my room all in a nice box shelf. How do i make a remote turn on for the set up when it is not hooked up to a car. Thanks everyone.
Posted By: auex
Date Posted: September 21, 2006 at 10:14 PM
All it does is supply +12V when the radio is turned on.
------------- Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Posted By: sub-zero
Date Posted: September 22, 2006 at 7:57 PM
So can i just ignore the blue remote wire on the radio and supply 12 volts to the radio from a car battery, or should i hook up the blue remote wire from the radio to the amps while plug in to the battery.
Posted By: auex
Date Posted: September 22, 2006 at 8:36 PM
Well, if you are just hooking up the radio then you want to power the yellow(constant) and the red(acc) wire and then ground the black(ground) wire. If you are using an amp then you need to worry about the blue wire otherwise leave it unhooked.
Posted By: sub-zero
Date Posted: October 02, 2006 at 6:36 PM
I would like to connect both my amps and sub woofer all together with the radio.
Posted By: soultinter
Date Posted: October 03, 2006 at 3:57 PM
you should buy a good size inverter (ac to dc) to power your radio and amp(s).
