wiring for H1 Hummer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83214
Printed Date: March 30, 2026 at 5:04 AM
Topic: wiring for H1 Hummer
Posted By: jimmy303
Subject: wiring for H1 Hummer
Date Posted: September 22, 2006 at 8:25 AM
Does anyone have the wiring for a 2002 Hummer H1 with the Monsoon sound system?
time is bending.....
Posted By: Velocity Motors
Date Posted: September 23, 2006 at 1:54 PM
You will probably have to grab any wires you want at the amplifier. What are you trying to do ?
Posted By: jimmy303
Date Posted: September 23, 2006 at 2:01 PM
Installed a Pioneer AVIC-Z1, but got it all figured out. The system uses a VW harness. VSS is one of two yellow wires behind the speedo. The other yellow wire is for the tach (good for remote start). The amp does not have a turn on lead, instead turning on when it see signal on the speaker leads, like the old school power boosters......
Posted By: jimmy303
Date Posted: September 23, 2006 at 2:03 PM
Never found the amp, though.
