dodge intrepid speaker wire routing
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8346
Printed Date: March 31, 2026 at 3:30 AM
Topic: dodge intrepid speaker wire routing
Posted By: big-e
Subject: dodge intrepid speaker wire routing
Date Posted: January 19, 2003 at 6:50 PM
I having trouble routing the wire to the speakers in the door. Any suggestions would be great.
Posted By: colguin
Date Posted: January 20, 2003 at 9:52 PM
what year intrepid do you have? I rewired my 95 intrepid and I had to remove the bottom part of the dashboard to feed the wires through. It was quite a pain in the rear. The parking brake is in the way and it would help if you had smaller hands. Inbetween the door and the car you'll have to pull up the rubber wire covering to help you feed the wires through. When removing the door panel, after removing the screws, pull the panel upwards and then out, and disconnect any harnesses or just have someone hold it while you pull the wiring through.
------------- Chris O.
