Alpine CDA-9857, XM and Aux-In Possible?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83543
Printed Date: May 03, 2026 at 7:06 PM
Topic: Alpine CDA-9857, XM and Aux-In Possible?
Posted By: intdump
Subject: Alpine CDA-9857, XM and Aux-In Possible?
Date Posted: September 30, 2006 at 12:23 PM
I have the following setup:
CDA-9857 (Ai-NET Connector) ---> XM Direct XMDALP100 (pass through Ai-NET Connector) --> KCA-121B RCA Interface --> DVD Player
I have set the AUX-IN mode on the CDA-9857 to ON but I am not able to get a signal from the DVD Player.  Is this setup just not possible, i.e., is the pass through on the XMDALP 100 not recognized by the CDA-9857?  I assume if that is the case then I would need to insert a KCA-410C Link Terminal in line before the XMDALP100.
Any  thoughts on the setup and whether a 410C would be required to have both XM and Aux-In would be appreciated (I hope a 410C ($$$$) is not necessary!!).
Thanks as always.
Posted By: tcss
Date Posted: September 30, 2006 at 12:36 PM
You do need the 410C, sorry.
There is no such thing as free installation!
