Do fuses affect sound quality?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83648
Printed Date: May 01, 2026 at 5:13 PM
Topic: Do fuses affect sound quality?
Posted By: quick94gt
Subject: Do fuses affect sound quality?
Date Posted: October 03, 2006 at 5:54 PM
  I just installed a ANL 200A fuse from the battery to the trunk, the stereo shop guy said thats what i neede, i have a Directed 1100D and a Directed 4200 in my mustang, will that many amps on the fuse affect sound quality at all? I used to have a 60A glass fuse before it was melted in the housing due to header heat (been taken care of)
Posted By: geepherder
Date Posted: October 03, 2006 at 6:39 PM
No affect.
Posted By: jonathancullen
Date Posted: October 03, 2006 at 7:22 PM
no the fuse just protects your amp from a short. it has no affect on SQ
Date Posted: October 03, 2006 at 8:43 PM
so should i add a fused distrubution block for the amps or will i be ok with the non fused distribution block and the fuses on the amp???
Posted By: cloak559
Date Posted: October 03, 2006 at 8:52 PM
Its always a good idea to have fuses wherever you can...but its not completely necessary...
'89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...
Posted By: DYohn
Date Posted: October 03, 2006 at 11:20 PM
A fuse should be used anytime wire size decreases.  The fuse should be rated at the capacity of the wire downstream from it, or if only one fuse is used it must be sized for the limit of the smallest wire.  So, yes it is a good idea if you use large wire (with a fuse at the battery) feeding a distribution block with smaller wire coming out of the block to use a fused block with fuses sized for the smaller wire, or to add fuses to the smaller wires just after the block.  And no, power fuses will not affect sound quality.
Posted By: TeddyKGB
Date Posted: October 04, 2006 at 12:51 AM
So if I have 0 gauge wire from my battery that has a fuse on it goig to a distribution block, then have 4 gauge wire going to each amp do I need a fuse on each 4 gauge wire?
2 Diamond Audio D3 12s
Hifonics ZXi1006 amp
MB quarts all around and a Panasonic up front.        You wanted to know don't lie...
Posted By: haemphyst
Date Posted: October 04, 2006 at 9:52 AM
Yes. No larger than 150A.
