Do i need more power?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83677
Printed Date: May 01, 2026 at 8:28 PM
Topic: Do i need more power?
Posted By: alexwrex
Subject: Do i need more power?
Date Posted: October 04, 2006 at 9:07 AM
Hello, i am very new to this so i beg you please have patience. I am about to run a sytem of the following :- 2x Fusion Powerplant speakers 2x Fusion Components 1 Fusion Amp and 1 Fusion Sub I want to run the sub off the amp and the other speakers off the head unit till i can afford to get another amp for them. I have already uprated the battery, but need to know wether it will be sufficient to power the whole system, or will i need to run a seperate battery for it? I am currently driving a reliant robin 1992!
Posted By: jeffchilcott
Date Posted: October 04, 2006 at 9:31 AM
What series amp? That will tell us how much power you are drawing....before adding a second battery it is best to upgrade what makes the power in the car, your alternaotr!
------------- 2009 0-1000 Trunk WR 154.0DB 2009 1001+ Trunk WR
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Posted By: alexwrex
Date Posted: October 04, 2006 at 9:36 AM
Apologies, I realise that you will need much more info so here are the specs:- 2x Fusion EN-CM65 240 WATTS COMPONENT SPEAKERS 2X Fusion EN-CM65 Tweeters 2x Fusion EN-CM65 X-OVERS 2X Fusion PP-FR693 Powerplant 6x9'' 3 Way Speakers 1x Fusion fe-402 Amplifier 1x Fusion 600 Watt Encounter Subwoofer 1x Pioneer DEH-P6800MP 50 Watt x 4 MAX OUTPUT or 50 Watt x2/ 4 ohmms +70 Watt x 1/2 ohmms (for subwoofer) I think that is it, any advice would be much appreciated as to how i should wire it/ what wire/ additional power source. Thanks in advance
Posted By: alexwrex
Date Posted: October 04, 2006 at 10:39 AM
Have just found out that my 1992 Reliant Robin has a 55 amp alternator. So will i need to go higher with the system spec i have?
Posted By: jonathancullen
Date Posted: October 04, 2006 at 1:56 PM
ive never even heard of a reliant robin lol, yes i would upgrade your altinator to a 140 amp just in case you want to add more power in the future. its better to have more power then you need, your headlights wont flash and your bass wont cut out during peak bass
Posted By: forbidden
Date Posted: October 04, 2006 at 2:01 PM
Update your profile to put the country that you are located in.
------------- Top Secret, I can tell you but then my wife will kill me.
Posted By: Flakman
Date Posted: October 04, 2006 at 2:09 PM
I would upgrade the "big 3" before shelling out the money for an alternator. ------------- The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
Posted By: austincustoms
Date Posted: October 04, 2006 at 2:19 PM
You really wouldn't need a high output alternator for a 400 watt amp. Like flakman said, just do "the big 3" and you should be fine. What kind of amp are you thinking about for the speakers?
Posted By: alexwrex
Date Posted: October 04, 2006 at 3:33 PM
From what i can workout with all the electrical items switched on in the car it would use 35 amps. And as my alternator is 55 amps even with just the head unit 200 watt and amp and sub 400 watt running, will that be too much for the battery to cope with straight off? I know it has killed my battery twice now so any advice you could give would be helpful. cheers In the Uk by the way
Posted By: alexwrex
Date Posted: October 04, 2006 at 3:38 PM
Got the specs for the amp i have, thought maybe i could get another one of these or maybe use this for the components and another for the sub? Fusion F-402 Specs: Price & Contact: MSRP $159 USD; www.fusioncaraudio.com Rated Power @ 12.5 VDC, 0.05% THD: 40 Watts x 2 into 4 ohms; 50 Watts x 2 into 2 ohms; 100 watts x 1 into 4 ohms Rated Power @ 14.4 VDC, 0.05% THD: 50 Watts x 2 into 4 ohms; 70 Watts x 2 into 2 ohms; 140 watts x 1 into 4 ohms Measured Power @ 12.6 Volts, less than 1% THD: 52.6 Watts x 2 into 4 ohms; 89.1 Watts x 2 into 2 ohms; 178.2 watts x 1 into 4 ohms Measured Power @ 14.4 Volts, less than 1% THD: 61.6 Watts x 2 into 4 ohms; 113.3 Watts x 2 into 2 ohms; 226.6 watts x 1 into 4 ohms Current Draw @ Max Power (14.4): 13.7 amps @ 4 ohms stereo; 24.3 amps @ 2 ohms stereo and 4 ohms bridged Efficiency @ Max Power (14.4): 4 Ohms Stereo: 62.5% @ 4 ohms stereo; 64.7% @ 2 ohms stereo and 4 ohms bridged Efficiency at 1/3 rated power: 4 Ohms Stereo: 30.4% @ 4 ohms stereo; 27.9% @ 2 ohms stereo and 4 ohms bridged Amplifier Weight: 6.5 Pounds (2.95kg) Amplifier Dimensions: 10.25 inches x 10.625 inches x 2.25 inches (260 mm x 220 mm x 57.5 mm) High-pass Crossover: Continuously variable 18 dB-per-octave from 40 Hz-6000 Hz Low-pass Crossover: Continuously variable 18 dB-per-octave from 40 Hz-160 Hz Bass Boost 0 to +18 dB @ 45 Hz Variable Subsonic Filter: Continuously variable from 20 Hz to 55 Hz @ 18 dB-per-octave Input sensitivity: 300 mV to 8 V Frequency response: 20 Hz to 55 kHz
Date Posted: October 04, 2006 at 6:33 PM
alright from what i am getting that one of your amps pushes 178 watts and the other pushes 70 watts right? you should get a better amp for your subwoofer, while underpowering a subwoofer is fine if you dont push your amp, but it wont be as loud as say a 500-600 watt amp to fully power the subwoofer. did it kill your battery while it was running??? i wouldnt think so but ya never know lol.
Posted By: cloak559
Date Posted: October 04, 2006 at 6:53 PM
HAHAHAH....Your car is awsome man!!!
 ------------- '89 Mercedes-Benz 300E
Pioneer DEH-5900UB
(2)RE Audio SX 10"s
(1)US Amps MD3D
3ft^3 @ 37Hz
Blowing up in a car accident doesnt worry me, as long as I'm putting out some major dB's when I die...
Posted By: alexwrex
Date Posted: October 04, 2006 at 7:26 PM
The only amp i have is the fusion fe-402 which is powering the sub, the other 4 speakers are running off the head unit which is pushing out 200 watt total. And the Reliant Robin is made completely out of fibreglass so the acoustics are amazing, the only good thing about the car.
