2007 Cobalt SS turn on lead?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83705
Printed Date: May 02, 2026 at 8:29 AM
Topic: 2007 Cobalt SS turn on lead?
Posted By: Silvrefox
Subject: 2007 Cobalt SS turn on lead?
Date Posted: October 04, 2006 at 7:36 PM
2007 Cobalt SS with the factory sub in the LR corner of the trunk, gonna do amp and subs with LOC. The only issue I'm having is does anyone know a safe place to grab the remote turn-on?
Posted By: Velocity Motors
Date Posted: October 04, 2006 at 9:09 PM
You need to grab it at the BCM. Use a switched ignition wire ( PINK ).
Posted By: Ravendarat
Date Posted: October 04, 2006 at 11:57 PM
Yep, DO NOT GO TO THE COLUMN. Must go to the BCM which can be accessed by pulling the pannel off the lower right hand side of the center console
Posted By: sparkie
Date Posted: October 05, 2006 at 3:07 PM
The pink wire in the 12 pin plug of the radio is the radio ON wire. Use this for your amp turn on.
sparky
Posted By: sparkie
Date Posted: October 05, 2006 at 4:36 PM
The pink wire is not an accessory wire. It is the remote amp turn on wire from the radio to the amp. It will likely go live even when you insert the key into the ignition cylinder because the amp has to be on to allow the chimes to come through the front lect speaker. It only takes a minute or so to pull off the trim panels and unscrew the radio. On newer GM vehicles, you can't hook into just any wire because some aren't designed to handle any current and only trigger microprocessers. If you son't know what the wire is and tap into it you can easily damage a BCM. Just a warning to be very cautious.
sparky
Date Posted: October 05, 2006 at 5:55 PM
I ended up catching it at the BCM (pink). Like a champ! Thanx to all yous guys that helped out.
