What amp to get
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=83945
Printed Date: May 03, 2026 at 7:49 PM
Topic: What amp to get
Posted By: oxygen65
Subject: What amp to get
Date Posted: October 10, 2006 at 12:44 AM
im looking at gettin a whole new set up in my car and right now im looking at 3 13w6v2's and either a massive audio p3000.1 amp or a earthquake PHD5000. the question i have is what amp is going to be better. the system is going to run at 3 ohms so im not gonna need all the power from either one of the amp. i havent really heard of massive audio so i dont really kno if it is a good product. i kno earthquake is a preaty good name in car audio. im also wondering is are they really gonna put out as much power as they say they are. i looked on both websites and they both say they are cea compliant but im still not sure if they will put out the actual numbers they say they will. can anyone help me out here?
Posted By: master5
Date Posted: October 10, 2006 at 1:45 AM
I will answer as best I can without being partial or basing anything on my personal opinion of products. If the amps are CEA compliant the specs are supposed to be true. You state you are running at 3 ohms. Regardless of what brand equipment you are using what you need to know is how much RMS power the amp will be delivering at 3 ohms. Divide that power by 3 since thats how many subs you are using. If it is within the power handling of the sub it should work fine. As a good rule of thumb it is better to overpower then underpower, within reason of course. Too little power will cause distortion and burn out the voice coils. Overpower within reason will produce "clean" power and leave some "headroom". You can always lower the gain in the worst case if you notice the cone is ready to jump out of the basket but can never compensate for underpowering by cranking the gains. However, if you go way overboard with power expect physical damage to the speaker. Good Luck.
Posted By: oxygen65
Date Posted: October 10, 2006 at 9:57 AM
ok well i kno preaty much everything you just said but anyways, i was more or less asking about the two companies and how good they are. that really all i wanted to know. so if anyone could tell me a little bit about massive audio and earthquake amps.
Posted By: supradude
Date Posted: October 10, 2006 at 10:04 AM
I can tell you that neither of these are true power RMS. They might claim they are but they're not. Same with Hifonics. I've got Hifonics and like their amps (for the price they cost) but if you ask them they will say their 2000 watt amp does 2000 watts, when it will actually do around 1400 RMS. To get a amp that really does you'll need to look at US Amps and companies that charge a LOT more for their amps. Earthquake and MA Audio won't do it.
'85 Toy
Posted By: DYohn
Date Posted: October 10, 2006 at 10:38 AM
Of the two companies you mention, IMO Earthquake is the better brand.
Posted By: kicker guy
Date Posted: October 10, 2006 at 12:09 PM
Yea out of those 2 id have to agree with DYohn and say earthquake
Posted By: master5
Date Posted: October 10, 2006 at 10:07 PM
Supradude, I thought "CEA compliant" meant they had to give honest power ratings, at least thats what I was told. But personally I never believe power ratings anyhow, especially on low-mid level products. In all actuality an amplifier is not supposed to alter the sound, just amplify it so besides reliability I don't think there is a major difference between one amp and another, power output being equal or close to it. Basically the "best" amp to use in this case would be the most powerful one you can afford at the flea market. Don't run it below it's ohm rating and expect weeks of nice bass before it needs replacment. Kidding aside, I have been installing for many ,many years and have seen some lower end amps pound and last forever but as with any electronics it's a gamble so try to get a good warranty, thats your only defense. Good Luck
Posted By: coppellstereo
Date Posted: October 10, 2006 at 10:29 PM
These are great woofers - what type of music do you listen to? What type of box?
Maybe you could go with 2 woofers and save money and buy a different amp?
Posted By: aznboi3644
Date Posted: October 10, 2006 at 11:25 PM
I thought the ruling was that it is impossible to damage a woofer by underpowering it??
Posted By: master5
Date Posted: October 10, 2006 at 11:43 PM
Nope. Most woofers are damaged by underpowering, I see it all the time, everyday. If you don't believe me ask ANY experienced installer and they will verify. Without getting too lengthy or technical I will explain this in a nut shell. Lets say your woofer as an average power rating of 500watts. You go on ebay and win a 20 dollar bid for a "Kenpine" amp which says "1000 watts" on it. However its average output is more realistically 100watts, if your lucky. Now as the sub wants alot more power and you want to hear boom and disturb the neighbors and intimidate the 80 year old lady in the car next to you the logical thing is to crank the volume. Since the amp does not have enough power to do what you want it is being overdriven into ungodly distortion levels, which you may not even notice since the bandpass box is hiding some and it is in the trunk. That distortion wreaks HAVOC on the voice coil, I don't care if its a W7 or a pyle, it will stop playing one day and you will blame everything and everyone but no matter how many times you replace the woofer... it blows. Good advice in that case...get an amp that can supply gobs of CLEAN power to the woofer and all is well. Keep in mind that slight overpowering is usually not an issue but go overboard and thats when you see things like the voice coil come out of its home and tears the spider assembly, or ripped cones etc. Like my mom always told me...."anything is ok in moderation"
Date Posted: October 11, 2006 at 12:47 AM
an IMPROPERLY tuned amp CAN damage a woofer through under-powering.
If you are not driving the amp PAST its limits, then there is no risk of damage.
Read threads about 'clipping' and 'square waves'
Posted By: master5
Date Posted: October 11, 2006 at 2:36 AM
I don't know if the previous post is directed at me but I will respond regardless. first off..what does an "improperly tuned" amp mean. An amp is supposed to amplify the input, not tune it. You set the gain and crossover but this has nothing to do with the issue of underpowering destroying woofers. About "driving the amp past it's limits" I guess that is assuming someone is going to install an amp/ sub and not crank it? I don't know what dimension you live in but here 99% of my amp/sub sales are kids looking to annoy everyone in a 10 mile radius with what I assume is some kind of music. alot of my customers blow woofers because they have bought the typical amp that says 6.25 gigiwatts on it but puts out a little more then deck power. As far as clipping and square waves I don't need to read any threads about that, I am an audio and electrical engineer and learned about that and how to use an o-scope the first week. Then I was teaching about that at an installation school for 6 years. But you proved my point, clipping is audible distortion which appears as a square wave on an o-scope. This clipping is caused by underpowering a speaker, like if you connected a 12''  600watt  sub to a  head unit power it would surely clip. The more severly you are under powering, the worse the clipping. But technical mumbo jumbo aside, I see first hand as an installer for over 15 years woofers blowing from under powering. When I install the proper amp I notice I am not seeing them every other day with blown subs. That my friend, is the reality of it. I wish all my customers listened at low volumes but thats like telling a hard core alcoholic to just sip your beer slow. Ain't gonna happen. Peace
Posted By: j_darling2007
Date Posted: October 11, 2006 at 8:31 AM
Master,  What you are describing is a user issue, not an equipment issue.  My dad has been powering an Infinity Reference 12 with a 50 watt Blaupunkt amp for about 8 months now with no damage.....why?  because he simply wants to round out the sound in his Jeep, not because he wants to intimidate people.  If he pushed the amp to clip the sub would be fried in an instant.
Their is no way that underpowering a subwoofer destroys it, it is when the operator cranks the amp past its limits into clipping that damage occurs.
And if you have all those qualifications you mentioned, that is great.  But their are alot of people on here with equal if not better qualifications (myself NOT included) that I have learned alot from.  I am not saying you are wrong, I am just saying that maybe you need to go at this with a little bit more of an open mind.
Jacob
There are 3 kinds of people in the world, those who can count and those who can't
Posted By: Flakman
Date Posted: October 11, 2006 at 10:38 AM
It doesn't matter if clipping occurs. It is when you drive the speaker past its thermal limits. So long as you keep within the limits of the driver, you will not burn out the voicecoil not matter how bad you clip the signal or how badly you "underpower" it.
I agree with j_darling2007 regarding your attitude. If you are so convinced that you are the Shiznit...you have stopped learning. On top of that, to disregard what has been previously posted and feel that you don't need to read what was said...that speaks for itself, and to the limitations of your current knowledge, and frankly, will cause people to stop listening to what you have to say regardless of whether or not it is valid or useful.
The Flakman
I feel strange. I have deja vu and amnesia at the same time.
John | Manteca, CA
Posted By: DYohn
Date Posted: October 11, 2006 at 10:43 AM
Where's the "beating head against a wall" icon?
Please read the "too little power" sticky thread.
Date Posted: October 11, 2006 at 3:39 PM
Soo...Master...as I stated the ruling stays forever until the world ends that you cannot underpower a woofer...Basically any speaker.
Posted By: master5
Date Posted: October 11, 2006 at 9:33 PM
Wow, didn't know this was gonna start a war. I did not reply earlier since I had to get some sleep and then get up for another day of installing and fixing all the disasters that "know it alls" have installed improperly  (the old "my homeboy did it")and have to replace incompatable equipment. But all this aside I really am an open minded person and I learn alot everyday. I just get a little rattled when I know something for a fact from of years and years of real world experience. Perhaps not everything can be proved on paper, or with diagrams and schematics, charts, scopes and specs etc, but I put my money on experience every time and leave the laws of physics and engineering to simply help prove points and try to help others not to make common mistakes I see every day. Just trying to help others save time and money. But the issue with this particular post has gone a bit off the deep end so I will try to clarify some of my statements since I think there is a misunderstanding. The issue seems to be what the definition of underpowering is (like depends what "is" is with Clinton) I am not so pigheaded as to think it is impossible to play a 5000 watt sub with a clock radio and that means the sub will blow. This is not what I mean. Also I think some of you do not understand the difference between a "damaged" speaker and a cooked voice coil. I also think many of you are not taking into account distortion, which is the number one cause for the old "my sub stopped playing". I don't know where some of you are getting your knowlege from but even before I knew what an ohm was I was told by every top notch installer, engineer, speaker manufacturer, rep, you name it that underpowering causes more returns and exchanges of subs then overpowering. Of course as time went on I found this to be the case first hand. I don't care if you want to call it clipping or anything, distortion will cause excessive heat and in turn fry a voice coil. Use common sense and think about what causes distortion and its effect. Also I hope you all understand that this is not about me trying to seem better then anyone else or holier then thou, I do not think that way about myself but I do know I have alot of experience and have worked very hard to get my degree and certifcations. That should be worth something but I will never say that I can't be wrong and welcome anyone to prove me so. I would be the first to say "I messed up, I'm an idiot" and take it as a learning experience. If anyone has felt insulted from my posts please don't take it personal as this way of communicating is VERY impersonal. If we were discussing and debating in person it wouldn't come off as it does on forums. Thanks everyone and enjoy while sharing, teaching and learning as I do.
Posted By: master5
Date Posted: October 11, 2006 at 11:08 PM
Also to nouseforname. I do not want this to become an aurgument as I think we actually are in agreement, just having an issue with terminology. You state "clipping is distortion that occurs when an amp is overdriven" I agree with that 100%. where I think we differ is what overdriven means. If an amp has enough power and is a match to the subs power handling what would cause it to be overdriven? Common sense as well as an understanding of what clipping is tell me that the output is basically "saturated" or in laymens terms it can't properly drive the woofer. There would be no logical reason to overdrive an amp if it had enough power. Am I missing something here? And this distortion we are talking about is what is frying voice coils, as I see almost everyday at work and when fixing systems for friends, family and side business. Good quality amps produce higher power levels at lower distortion. Low quailty amps may produce high "peak" output but it is rated at high distortion levels which kills voice coils, I see no argument of that fact. In another scenereo lets assume a good quality amp but low power, lets say 100w RMS @ 2ohms. This amp should produce clean power to 100 watts @ 2ohms. but if some knucklehead SPL junkie is trying to power a 5000 watt JBL with it he will most likely run that amp into distortion or as you put it "overdriven". I don't know what anyone else thinks but I see a problem with that.  Add to this a ported box that may have a 3db higher output at Fs but the power handling is now even more reduced as you go below the tuned frequency, another recipe for disaster. As far as gain control setting there is always debate about that. from everything I know about gain control is that people think it is a volume control and others think if you turn it up the amp will be more powerful. neither is true. A 200 watt amp does not become a 400 watt amp if you crank the gain. The gain is designed to correct input impedance mismatch since there are no industry standards for this. In the days of yor, when I started installing (age 15) if you purchased lets say, an Alpine deck, you HAD to use an Alpine amp. They didn't even use RCA's they used din cords which were different for each brand. Most amps at that time didn't have gain controls. Didn't need them as the equipment was matched. As the business grew people wanted more choices so we had to either re-pin the din cables or sometimes the aftermarket would sell pre made ones..example "sony to pionner"  or "blaupunkt to alpine" etc. At times there was problems since there was no way to adjust the gain so on some decks you would not have enough volume and on others the inputs were overdriven, essentially driven into saturation, in a sense you had distortion before the audio even got to the amp. All this aside please understand I am also here to learn, not just teach but have a right to stand my ground if I feel I am being accurate. I hope we can see eye to eye on many topics as I can tell you are very experienced and would like us to learn from each other which I guess is the purpose of this whole site. Peace
Posted By: master5
Date Posted: October 12, 2006 at 6:13 AM
someone told me to divide my long replys into paragraphs so it will be easier to read.
I will try to remember to do that in the future as I am new here and LEARNING.
