Subwoofer Enclosure
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8447
Printed Date: April 01, 2026 at 6:54 AM
Topic: Subwoofer Enclosure
Posted By: Knight2000
Subject: Subwoofer Enclosure
Date Posted: January 22, 2003 at 10:59 AM
Hi, i got a question for all you guys, i hope you can help me.   I Have a 10" sub and in the specs says that the required INTERNAL NET VOLUME is 0.625 cubic feet.  To this you need to add the Driver Displacement to get the final volume.  My question is, if this volume is the minimum, tha maximum or the perfect for this Sub, and what happen if i make a bigger enclosure?.  Thanks
Posted By: F4Pilot
Date Posted: January 23, 2003 at 3:24 PM
Depends on the sub and the type of enclosure.  Performance of the sub itself will be affected by the size.  Resonating frequency will change with the volume or size of the enclosure.  Any decent sub manufacturer will include product literature which details this information for you to customize the sound.
Posted By: wvsquirrel
Date Posted: January 23, 2003 at 11:06 PM
Usually the specs from the manufacture are for the best overall performance of the sub.  As F4Pilot stated, you can change the size of the box to change the response.  A common, easy way to do this is put insulation inside the enclosure.  It changes the resonating frequency and, if I'm not mistaken, makes the sub perform as if it's in a larger box than it really is.  If you want to go smaller, but don't want to rebuild the enclosure, then add some extra MDF inside the enclusure to reduce available airspace (make sure to seal around the new wood to keep it airtight).
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
