legacy dvd/ mp3 player problem
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84614
Printed Date: April 02, 2026 at 8:25 AM
Topic: legacy dvd/ mp3 player problem
Posted By: will_22_82
Subject: legacy dvd/ mp3 player problem
Date Posted: October 25, 2006 at 12:32 PM
yesterday i hooked up my new inline fuse running 150 amps. okay the system worked but the bass made the deck jump causing a error to where I could not turn the bass off using my remote, the menu key. so i reset the unit from the deck and thus i could not turn on the subs again. the menu button works because i can access the menu still by pushing it. where as before i could access the subs, but not the menu. everything seems to be hooked up right, and the deck is functional. So i have no clue what would be the problem. also the eq button controls the loud option, where as it sometimes controls the settings like rock, classic, etc. is it a malfuntion or what? how can i correct this?
Posted By: aznboi3644
Date Posted: October 25, 2006 at 8:25 PM
Is this an actual Legacy unit???
If it is made by Legacy, your problem may be that Legacy makes the cheapest crappiest stuff out there and that this is just a piece of crap and broke...sorry will
Posted By: stevdart
Date Posted: October 25, 2006 at 9:15 PM
Legacy is not known to have problems. It must be user error.
------------- Build the box so that it performs well in the worst case scenario and, in return, it will reward you at all times.
Date Posted: October 25, 2006 at 10:45 PM
Well alteast their head units work but I'm not too fond of their speakers
Date Posted: October 31, 2006 at 7:58 PM
the remotes contacts wore out after 6 months of use. New remote 20.00 dollars.
Posted By: jonathancullen
Date Posted: November 01, 2006 at 11:09 PM
a cd player is a cd player, they all work but for how long? my friend has one 12" jensen in a big box and it can fart and make the mirror shake a lil. just a little bit though xD
Posted By: stevdart
Date Posted: November 01, 2006 at 11:30 PM
Thank you for that thought, Jonathan.
