crossover frequencies
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84636
Printed Date: April 02, 2026 at 6:00 PM
Topic: crossover frequencies
Posted By: novice8540
Subject: crossover frequencies
Date Posted: October 25, 2006 at 6:07 PM
I have a 12 inch. JL W7, and a JL 1000/1, what is the highest crossover frequency I can have it at?
Posted By: haemphyst
Date Posted: October 25, 2006 at 6:12 PM
Whatever sounds good to you, but in general, I'd never run a 12 higher than about 80 (maybe 100 Hz), and then only with a VERY steep crossover slope - greater than 36dB/octave. In my system, the subs are set to 50Hz, and 48dB/octave, but I like true subwoofers, not detached woofers.
Posted By: DYohn
Date Posted: October 25, 2006 at 6:38 PM
80Hz is the industry standard subwoofer crossover frequency.
Date Posted: October 26, 2006 at 8:45 AM
So is 120 Hz bad?posted_image
Posted By: DYohn
Date Posted: October 26, 2006 at 9:42 AM
Not necessarily.  120Hz is too high for non-directional bass, but it might be what works best in your vehicle.  Where is the high-pass set for your mains?  It should be the same frequency and slope.
