Alternator whine
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84898
Printed Date: April 17, 2026 at 6:39 AM
Topic: Alternator whine
Posted By: SoundAudio
Subject: Alternator whine
Date Posted: October 31, 2006 at 4:08 PM
I have a Pioneer D1 in an 05 Mercury Mariner. I have already grounded the RCA's and it supressed the alternator whine but there is still some present. What should I try next, a ground loop isolator, or a noise filter on the power to the D1? Thanks for the help.
Good Luck!
-Thad
Posted By: aznboi3644
Date Posted: October 31, 2006 at 4:58 PM
Um...try making a new ground for the D1.
Also do your amp ground good???
Posted By: forbidden
Date Posted: October 31, 2006 at 5:26 PM
^^^^ speak English there Asian Invasion, not Engrish.(the grammer police were looking over my shoulder)
What have you done to the amps ground and read the grounding sticky.
Date Posted: October 31, 2006 at 5:44 PM
haha my bad...I had overlooked that...shut up forbidden!!!
I meant does your amp have a good ground??? Must have spaced out while typing lol
Date Posted: October 31, 2006 at 7:12 PM
I have two amps MB Quart RAA1000 and RAA4200. 4 ga. each to a distro block and then 1/0 ga. to a stinger grounding terminal. Grounded to floor pan in the back where the metal has been grinded clean and the terminal is bolted down. I had ruled out the amps because I tried the setup with the factory stereo and a PAC LOC while the D1 was being repaired for the touch screen. The ground on the D1 is to the metal subframe behind the dash. Should i put a noise filter on power and ground for the D1? Thanks guys!
Good Luck!
-Thad
Date Posted: October 31, 2006 at 7:21 PM
Disconnect the head unit from the amps. If the noise is gone, the head unit is the culprit and no amount of filters is going to fix a broken headunit.  Thad, if you can borrow another head unit to try as well, preferably not a Pioneer.
