suggestions needed
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=84906
Printed Date: April 17, 2026 at 3:18 AM
Topic: suggestions needed
Posted By: badassgixxerboy
Subject: suggestions needed
Date Posted: October 31, 2006 at 6:26 PM
I bought a sub without doing research on the inclosure requirements. I also built the inclosure before reading the requirements. The sub is made for a ported box at 2.4 square feet and I made a sealed box that's under 2 square feet. The reason for the oversight is I built the box to fit the vehicle without considering the subs best performance. I'm not looking for perfection, of course, but I want to get the best sound available with what I have. Any suggestions?
Posted By: stevdart
Date Posted: October 31, 2006 at 7:13 PM
Name the sub model and the vehicle it's going in, please.
Posted By: haemphyst
Date Posted: October 31, 2006 at 7:19 PM
noneedforaname, why did you decide to come back? I know you were formerly known as nouseforaname, and I notice that account is labelled "inactive". What did you do to have that lovely title appended to your previous monacre? Are we going to attempt another post race?
Posted By: forbidden
A sealed box is highly forgiving as far as volume goes. Generally speaking, a 30% margin of error on box volume is necessary before it will become highly noticeable as a drop in performance. In most but not all cases, the sealed box is usually 25% smaller than the spec ported box is. I think you should drop in on in and give it a try.
Stevdart needs the info on the sub as well. Ideally if you can post the exact dimensions of the box as well, someone might be able to confirm the new porting requirements for the smaller box.
Posted By: geepherder
Date Posted: October 31, 2006 at 7:51 PM
Dave, post race- that's hilarious, what happened? Does is it have something to do with Denzel's new movie coming out next month?
Date Posted: October 31, 2006 at 8:24 PM
The sub is a power acustic mofo 12".  I don' t have the exact dimensions of the box but it's around 23" l x 15"w x 13"t. The manufacturer didn't list a sealed spec so I am assuming that they didn't intend on it being in a sealed box. Will this cause the sub to blow or anything by it being in a sealed box?
Date Posted: October 31, 2006 at 8:25 PM
By the way the vehicle is a 2004 ford f-250 crew cab.
Posted By: killer sonata
Date Posted: October 31, 2006 at 8:30 PM
you could always throw some polyfil in the sealed box to give the illusion to the sub that its in a bigger enclosure
Date Posted: October 31, 2006 at 8:31 PM
Date Posted: October 31, 2006 at 9:31 PM
I have some polyfill in the box already and have a so called 1000 watt amp (sony xplode) pushing the supposed 2400 watt sub. I'm hoping to get something better soon, real soon. Thanks for all the info.
Posted By: stevdart
Date Posted: November 01, 2006 at 9:14 PM
I looked at the web site regarding your sub and the list of T/S parameters they provide. That sub will NOT perform as expected in a sealed enclosure. It has an EBP of 102, which is way into the vented category.
Look at these specs: Fs and Qes. EBP is the result of dividing Fs by Qes. The EBP is a valuable indicator of how a woofer will perform given the different enclosure types; 50 and below is a definite sealed category, above that to about 70 is an iffylookatitbothwaysanddecide situation, and anything above 70 (some would say 90)is a definite vented situation. At 102, this sub needs the vented box.
Anything smaller than the 2.5 cu ft or so they suggest will result in a loss of low end bass response. And you can be sure that they are not going too big here with this suggestion, as space is always a premium in car audio. That is to say, if it would work okay with 1.75 cu ft they would readily recommend that size.
Mo' money, but I suggest you find a different sub that will perform well in the enclosure you have, as it fits your truck. There are plenty to choose from.
The MOFO is marketed as an SPL sub, and to the maker's credit they are making no pretenses to sound quality. With the right box and appropriate power, you can achieve loud sound. But just that, loud sound. If you would prefer a more musical subwoofer, look toward brands that are known to contribute SQ to your listening experience.
Posted By: aznboi3644
Date Posted: November 01, 2006 at 11:45 PM
Ahh...NoNeed I though you were a punk bastard trying to copy off of your former NoUSE..lol
