how many watts do u get when u wire 2subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85265
Printed Date: May 03, 2026 at 9:30 AM
Topic: how many watts do u get when u wire 2subs
Posted By: ggalan
Subject: how many watts do u get when u wire 2subs
Date Posted: November 06, 2006 at 11:27 PM
i am wiring 2 subs that are 4 ohm dual voice coil in parallel/parallel to get a 1 ohm load they are both 1000 watts  and i want to figure out how many watts do i get at the end.
gg
Posted By: DYohn
Date Posted: November 06, 2006 at 11:33 PM
You "get" how ever many watts the amplifier is capable of producing.  If you connect two woofers, the power is divided between them.  If you use one woofer, all the power is used by one.
