Need help on choosing an amp
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8547
Printed Date: April 02, 2026 at 1:38 AM
Topic: Need help on choosing an amp
Posted By: mrtravieso
Subject: Need help on choosing an amp
Date Posted: January 24, 2003 at 6:50 PM
I just bought a pair of 12" ONYX subs, rated at 400w rms each, I was told they can handle possible 500-550w rms each....I need an amp for these, they are dual voice coil 4ohm.  what amp do you guys recommend and how should I wire them?  I was thinking of wiring them parallel, which would give me a 1 ohm right?  if i'm wrong, please correct me, I can use all the help I can get
one more thing, i don't want to spend too much for the amp, something cheap but with nice solid performance....please help.  THANKS
Posted By: pervitizm
Date Posted: January 24, 2003 at 10:15 PM
Posted By: eedukes
Date Posted: January 25, 2003 at 8:04 AM
 I have two Kicker 12 Comp VR that are rated at 400 watts RMS. I have a JBL BP600.1 on these subs and they pound hard. You can get these online for under $200.00. If thats not enough for you, then try the bigger brother, the BP1200.1. Ive seen it online for $260.00. The 600.1 is underrated at 600 W RMS in a two ohm load. The 1200.1 is underrated at 1200 W RMS.
Date Posted: January 25, 2003 at 11:12 AM
if i connect my subs parallel, i get a 1ohm resistance don't I???  don't i have to get an amp that runs a 1ohm load?
