06 crew cab bose onstar
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=85899
Printed Date: March 28, 2026 at 9:10 PM
Topic: 06 crew cab bose onstar
Posted By: stereoguyz
Subject: 06 crew cab bose onstar
Date Posted: November 20, 2006 at 2:05 AM
Having problems with onstar, using the stock radio added all aftermarket amps and subs, bose amp is still connected, bypass is done at factory amp.  Onstar is still powered up and cuts out audio on stereo but nothing else is heard on phone or onstar. I have tested outputs from factory amp with oem speaker and cannot get onstar to produce any sound.  I want to add one of the factory speakers into the dash somewhere so that i can have onstar audio while retaining aftermarket amps and subs.  Also i need the correct wire for retaining amp power when key is removed. thanks in advance....
Posted By: mike12volt
Date Posted: November 21, 2006 at 8:48 PM
Vehicle description will help for replies. Sounds like you're mixing OEM amp with aftermarket amps, even though you specified above that you replaced the Bose/OEM amp. Makes no sence.
Date Posted: November 21, 2006 at 8:51 PM
Sorry, You did mentioned "added". What harness did you use to bypass the amp (Bose amp)?
Posted By: master5
Date Posted: November 22, 2006 at 5:45 PM
It is strange that you lost the onstar audio since to state you retained the factory deck and amp. I am hoping nothing in the system was damaged. I can only suggest to check if any wires are cut or tapped into at the deck causing this problem.
You vehicles factory deck uses RAP (retained accessory power) which has no acc voltage at the deck. It is a class2 data system so if you tapped into anything other then speaker wires, constant or ground it could cause problems so double check that first. Otherwise there may be permenent damage, just have to keep your fingers crossed on this one.
For a remote wire there are a few options. One is to find the RAP relay or fuse. Use a meter to find a wire with 12v that stays on once the key is turned off and goes to zero when the door is open. This can be a pain and time consuming but it's there somewhere. Perhaps if someone knows the specific location of the wire they will post it. Going to any other acc fuse of brown wire at the ign. harness will result in the amps turning off as soon as the key is turned off.
Option two is to buy a "remote power adaptor". DEI sells one for around 11 bucks. It uses the audio signal from a speaker wire to turn on the amp as soon as the deck is on..and wil leave it on until the deck loses power. A cheap,simple solution if you can't find the right wire.
Good Luck
Posted By: geepherder
Date Posted: November 23, 2006 at 12:30 PM
Did you test the onstar prior to adding your gear?
The power windows should be on the RAP circuit as well. Maybe you can find power there, even if only to drive a relay.
Date Posted: December 12, 2006 at 2:51 PM
2006 chevy silverado crew cab 1500
Retaing factory look and adding aftermarket speaker and amps.  Amp bypass done using high to low pac converter...  Speaker wires cut after Bose amp direct connection from aftermarket amp to speakers using factory wiring   High to low used at same location (output) of amp... I didnt test onstar unit because i was using a periferal mod, the rca outpus on mod were very low and the amps didnt put out much sound, so then i went to high to low conv.
When the onstar is pressed the radio is cut off but no sound, onstar can hear customer but customer cannot hear them
plan to try another Periferal mod......
Posted By: master5
Date Posted: December 12, 2006 at 4:21 PM
If I understand what you posted correctly you did not actually bypass the factory amp, you attached the converter to the outputs. If this is the case all audio should be coming from it...including onstar..the type or brand of converter you use should not be able to tell if its the onstar voice or any other audio source.
So I still think you need to check into this more or be more specific with what you actually did. And/or as asked earlier to make sure that the onstar worked before you "tampered" with the system or if it is not anything you did that is causing this issue and is just a defective onstar unit.
Good Luck.
Date Posted: December 12, 2006 at 7:29 PM
Well put, master5.
Date Posted: December 13, 2006 at 7:19 PM
Your on the same track as i am, i've never had any problems with this before, but its my 1st 06, they didnt seem to change anything.  I tend to think something is wrong from the factory because the customer stated just last night that his Temp and Compass on the rear view mirrow are not working eaither, and they were working fine when i delivered the car.   I wonder if there's something wrong with that whole unit.....
