Dual 1 Ohm VC Subs, finding an amp and Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8632
Printed Date: May 08, 2026 at 12:33 PM
Topic: Dual 1 Ohm VC Subs, finding an amp and Wiring
Posted By: 1997AvengerES
Subject: Dual 1 Ohm VC Subs, finding an amp and Wiring
Date Posted: January 26, 2003 at 7:12 PM
What kind of amp can I buy to run a dual 1 Ohm voice coil sub THX
|||||||1997 Doge Avenger ES was here|||||||
Posted By: bberman1
Date Posted: January 26, 2003 at 8:10 PM
Each voice coil is 1 ohm? So when wired together in parallel they present a ½ ohm? That doesn’t sound correct .Or do the 2 coils wired together present a 1 ohm load? Also who makes the sub and what’s the model number?
