Adding clean sweep to ’06 Avalanche nav
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=86364
Printed Date: May 11, 2026 at 4:54 PM
Topic: Adding clean sweep to ’06 Avalanche nav
Posted By: Ren92
Subject: Adding clean sweep to ’06 Avalanche nav
Date Posted: November 28, 2006 at 8:40 PM
I have a 06 Avalanche with the fact Nav and Bose combo. I the Clean sweep and the CL-SSI and went to the spkr output at the doors but I am not getting a clean signal at all. Anyone done this truck with a clean sweep and have good luck and if so where did you pick up signal for the units?
Posted By: 2old4gamez
Date Posted: December 13, 2006 at 3:43 PM
if your truck has a factory amp, then u need to hook the cleansweep up to the speaker inputs at the factory amp.
