desperately seeking wiring diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8644
Printed Date: May 08, 2026 at 7:53 AM
Topic: desperately seeking wiring diagram
Posted By: rotten
Subject: desperately seeking wiring diagram
Date Posted: January 27, 2003 at 8:04 AM
help.  im in dire need of a wiring diagram for a 95 ford windstar. thanks in advance
rotten
Posted By: Velocity Motors
Date Posted: January 27, 2003 at 8:16 AM
|              12V|yellow              |+  |ignition harness            |
|          STARTER|wht/pnk or RED / blue |+  |ignition harness            |
|         IGNITION|RED / green           |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ green         |+  |ignition harness            |
|        ACCESSORY|gray / YELLOW *1      |+  |ignition harness            |
| SECOND ACCESSORY|BLACK/ pink          |+  |ignition harness            |
|       POWER LOCK|pink / YELLOW         |-  |drivers kick panel *3       |
|     POWER UNLOCK|pink/green          |-  |drivers kick panel *3       |
| PARKING LIGHTS +|WHITE/ black *4      |   |light switch                |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|RED / yellow          |+  |at light switch             |
|     DOOR TRIGGER|BLACK/ blue          |+  |kick panel                  |
|  TRUNK/HATCH PIN|common with doors   |   |                            |
|         HOOD PIN|black               |-  |at sw under hood            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|GREEN/ purple        |-  |either kick panel           |
|       TACHOMETER|gray/orange         |   |EDIS module *2              |
|       BRAKE WIRE|RED / lt. green       |+  |brake pedal switch          |
|     HORN TRIGGER|YELLOW /GREEN        |-  |ignition harness            |
|           WIPERS|                    |   |                            |
|  LF WINDOW UP/DN|wht/yel - yel/blu   |A  |driver's door switch        |
|  RF WINDOW UP/DN|wht/yel - yel/blu   |A  |driver's door switch        |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 May be more than one - test to verify which one powers blower and A/C controls.  *2 Six-cylinder EDIS module on passenger side fender wall underhood.  *3 The keyless module is behind center storage compartment.   *4 One of two, only one is pkg lt.
