best tweeter location
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8665
Printed Date: May 08, 2026 at 4:13 AM
Topic: best tweeter location
Posted By: dyer
Subject: best tweeter location
Date Posted: January 27, 2003 at 4:49 PM
I have a 2002 avalanche. I'm installing mb quart psd 216 component speakers in the front and back. Where do you feel are the best locations for the tweeters? Lower doors (right below woofers)? Upper doors (little above woofers-stomach level)? or pillars (right next to ears)? I've heard that closer to the ears the better, but I don't want to go deaf! What do you guys think! Thanks
------------- Dyer
Posted By: lan_ke
Date Posted: January 28, 2003 at 1:33 PM
the best location is in the dashboard,in the corner and you can angle the tweter to centre spion for get better imaging.....placement is very important if you are mobile audiophile...:)
Posted By: lan_ke
the best location is in the dashboard,in the corner and you can angle the tweter to centre mirror for get better imaging.....placement is very important if you are mobile audiophile...:)
Posted By: dyer
Date Posted: January 28, 2003 at 5:08 PM
So for the front... you say for me to put them in the corner of the windshield area on the dash facing the rear view mirror. Right? Is it the place where the 2003 chevrolet trucks have the factory tweeters? Would they be bouncing off the winshield? What about the rear speakers? Thanks for helping
------------- Dyer
Posted By: lan_ke
Date Posted: January 28, 2003 at 10:38 PM
yes,facing for the rear view mirror.But you must trial and error again for best imaging because your dashboard and cabin acoustic. I don't know about chevrolet 2003 tweter location,bcz i don't know about the chevy interior. Rear speaker is normal placement,at the factory place if have,the important is only you must try for bridged mono the rear speaker,i found the rear speaker is very help front stage sound reproduction if i configure the speaker cable in mono(like sub). Sorry,i'm from asia so the english is not good. :).If you don't understand,pls e-mail me,i try for help you.
Posted By: Big Purds
Date Posted: January 29, 2003 at 2:39 AM
I would advise keeping the tweeters as close to the woofer as possible...above or maybe in front of the woofer itself, and aimed properly... are the psd tweets anything like the qsd tweeters? I find that I prefer the qsd tweeters low, because to me they are kind of bright...I dont like that in my face... are you doing a custom install with fibreglass kick panels or pods?
Posted By: dyer
Date Posted: January 29, 2003 at 8:46 AM
The psd tweeters are similar to the qsd. I have locations for the woofers, just not the tweeters. The factory front speakers were separate components, so I can use the factory locations for the front tweeters (right above woofers). I was just wondering if there is a better location for them besides factory. However, the rear speakers were coaxial, not component. So I need to locate an area for the rear tweeters. Should I just put them as close to the woofer in the door as possible? They may be almost 1.5-2ft away from the woofer. is that ok? Thanks to both of you for helping. Any more advise from yall or others would be great!
------------- Dyer
Posted By: pain_is_lov3
Date Posted: January 29, 2003 at 10:43 AM
I would say mount them in the corner of your side windows on the sail panel (witch will be the panel that your side mirror is located).....mount them on the other side. That way it is closer to your ears and not to far away from the midbass driver and very good imaging if the tweeter can swivle.
Date Posted: January 29, 2003 at 1:21 PM
well, stock locations are almost never ideal...most cars arent designed around their audio systems, heh...you would really be better off as far as sound quality is concerned to build your own fibreglass enclosures, for the fronts especially...but if you arent into these kind of intensive modifications, the factory tweeter location will be as good as any probably... when I asked about psd and qsd tweeters being similar, I meant in sound, not size...do they sound alot alike?
Posted By: dyer
Date Posted: January 29, 2003 at 9:10 PM
Thanks for helping. As far as qsd vs psd. They sound similar, but the qsd do produce a cleaner sound. I'm not really interested in going too custom. I don't want to bother with custom enclosures. What about the rear tweeter locations? Thanks again for everyones input. I'm considering it all. Please keep it coming!
------------- Dyer
Posted By: dyer
Date Posted: January 31, 2003 at 8:38 AM
anyone have any suggestions for rear tweeter locations?
------------- Dyer
Date Posted: January 31, 2003 at 9:48 AM
Mount them on the panel that is between the rear and front side windows.
Date Posted: January 31, 2003 at 3:41 PM
you typically dont want alot of tweeter action coming from behind you, I would probably just not bother with th tweeter and run the woofer full range... that is my personal opinion, tho, and I have NEVER had rear speakers...I have taken them out of vehicles because I believe in a strong front stage and believe Surround Sound is for Home Theatre...so I may not be the guy to ask here, lol...
