MB quart speakers
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8698
Printed Date: May 08, 2026 at 1:22 AM
Topic: MB quart speakers
Posted By: king244
Subject: MB quart speakers
Date Posted: January 28, 2003 at 1:38 AM
ok, did someresearch on MB quart ...there are several different models in the 6.5 version....question, which will fit in the doors of  a 2001 dodge ram with the tweeters? and which are the better sounding models?
for the subs, do you also reccomend mb quart, maybe the 10 inch...
what is a good amp nowadays, not expensive yet still clean and reliable....?
Posted By: Velocity Motors
Date Posted: January 28, 2003 at 10:20 AM
For the Dodge doors, you will need to make an adaptor plate out of PVC or MDF for fitment of a 6 1/2" speaker because the stock speaker is a 6 x 9 . The tweeter will also need a special plate made because the OEM tweeter is about 2" in diameter while most aftermarket tweeters are about 1 " i diameter. I would suggest going with a 12" sub instead of the 10 " just for the fact that I like the sound of a 12"  as opposed to a single 10". A good amp to run this system would be a MTX 8302 or an Xtant A6001 would be a good choice as well.
