amp in protection mode
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87209
Printed Date: May 11, 2026 at 1:41 PM
Topic: amp in protection mode
Posted By: kingerik68
Subject: amp in protection mode
Date Posted: December 14, 2006 at 4:04 PM
I've been running an audiobahn amp to 2 pairs of audiobahn component speakers and another audiobahn amp to a pair of subs. Recently my components jus stopped playing music and now jus this popping sound (my subs still play). I looked at my amp and it's flashing in and out of protection mode. I think the power light is on as well but i might be mistaken. Can anybody tell me what might cause this
Posted By: rudydapimp
Date Posted: December 14, 2006 at 5:06 PM
 i would check the ground.  also, what load are you putting on the amp from your components?
Posted By: jettagli03
Date Posted: December 14, 2006 at 5:09 PM
first off you have audiobahn amps...
Date Posted: December 14, 2006 at 6:58 PM
i think 75 watts by 4 @4 ohms
Posted By: i am an idiot
Date Posted: December 15, 2006 at 6:43 AM
   If the popping sound is a consistent timed pulse,  meaning every 5 or 6 seconds there is a half second of sound.   You have shorted output transistors in your amp.
Date Posted: December 15, 2006 at 10:34 AM
that's exactly what it sounds like.. is this expensive to fix? would i have to replace the whole amp or jus parts of it? thanks for your help
Posted By: jeffchilcott
Date Posted: December 15, 2006 at 12:27 PM
more then likely, it will be more expensive to rebuild the amp then it would cos to buy another one.   Audiobahn is not the most reliable name out there.
looks like its time to upgrade
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Date Posted: December 16, 2006 at 8:18 AM
Nope not expensive to fix.  Do you have a digital Volt/Ohm  Meter?  or have access to one       you will also need a 2.5MM Allen wrench   a soldering iron and some solder    and some desoldering braid available at radio shack.
It will take 2 parts  that you can get online for about 5 dollars each  plus S&H
