Issues with Deck swap in ’07 Caliber
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87237
Printed Date: May 11, 2026 at 10:24 AM
Topic: Issues with Deck swap in ’07 Caliber
Posted By: calibro
Subject: Issues with Deck swap in ’07 Caliber
Date Posted: December 15, 2006 at 10:01 AM
So yea.... I went out and got a sub, amp, speakers and a deck. ( I have a Caliber STX with std Audio)
Deck --> https://www.2001audiovideo.com/product_info.php?id=DEHP6800&clr=
The main problem I am having is with the faceplate (bracket) to go from the huge deck (stock) to my new deck. In most cars a simple bracket would work, but in the caliber the volume and tuning knobs bulge out of the unit and have bevels in the dash...Why dodge would do this I dont know....m0r0ns. This complicates things as there will be holes in the dash if I use a regular bracket.
Has anyone here swapped decks in the caliber?? If so, can you recommend a place to get a good bracket for mine?
Thanks, Matt
Posted By: ss-installer
Date Posted: December 16, 2006 at 9:46 AM
American International kit  # CDK-648.
Posted By: jvillefinest
Date Posted: December 16, 2006 at 8:03 PM
ummmm....you know retail on that deck is 269.99 and that is for the Pioneer Premier one, with the 2 year warrenty from Pioneer. But yea that dashkit should work forya.
2007 Acura TSX
SQ setup in the works
Posted By: calibro
Date Posted: December 17, 2006 at 11:29 AM
I got the deck on sale for 254.99....thats the only reason I got it. I would never spend 320 on a deck. And yea when i saw the reply in this thread i went to bestbuy and told the guy and got a '04 durango mount....which works perfectly.
So I spent a good 4-5hrs on my car yesterday running lines and mounting the amp/deck/speakers while the caliber was in pieces. A little intimidating...but everything went back together cleanly. However, the closest wiring harness i could find was for a dodge durango '04...which has a few problems. 1....right now I don't have access to an ignition lead from the car...so uness i turn off the radio/remove the faceplate...it never turns off. 2....rear speaker pins on the stock connector don't line up with the ones on the mount. I am going to see if i can remove and re-place th pins to manuallt align them up.
The thing with the ignition wire is a bigger problem though. I searched all around for a wiring guide and the only 2 I found were from this forum (see below) and another place which i couldn't understand.
Radio 12v           RED / lt. blue
Radio Ground         BLACK / YELLOW
Radio Ignition         (CAN data bus)
Radio Illumination      N/A
Factory Amp Turn-on      (CAN data bus)
Power Antenna         gray/red
LF Speaker +/-         gray/purple       - gray / YELLOW
RF Speaker +/-         dk. GREEN/ pur     - dk. GREEN/ yel
LR Speaker +/-         dk. grn/dk. blue - dk. grn/brn
RR Speaker +/-         gray/dk. blue     - gray/orange
Can anyone tell me what CAN data bus means?? I need to find that wire for Radio Ignition!!!!!! It's driving me nuts
Thanks for all your help.
-Matt
Posted By: geepherder
Date Posted: December 17, 2006 at 6:55 PM
It basically means that a computer module sends a data signal to the factory radio/amp, telling them to come on. There isn't a switched wire at the radio harness. Test for an accessory wire with a meter (cigarette lighter, ignition harness, etc.).
Posted By: calibro
Date Posted: December 17, 2006 at 8:11 PM
YAAAA Good call...don't know y i thought of that...Thanks
Posted By: 05gt
Date Posted: December 17, 2006 at 8:16 PM
you need this module from peripheral electronics CHYAH05, it is the 05 to present chrysler CAN-BUS module
there is a three digit with letter code on the front of the factory radio, this module can only be used on certain ones
it retails for about 149.99
Posted By: calibro
Date Posted: December 17, 2006 at 10:00 PM
Thanks...but i'm probably just going to run a lead off the 12volt cigarette jack. It will take me 2 min to do it.
My next thing is to see if I can use the IP-Bus aux-in on the back of my deck and run a line to the console where my mp3 player will sit. I'm an iRiver man....not an iPod man.. so the iPod deck addon won't help me.
I must say that now that I have ripped apart my car and know how easy it is to remove stuff....I can do anything in it now....YESSSSS
Posted By: loosingmymind
Date Posted: December 18, 2006 at 12:27 AM
Metra Kit 99-6510. There's also an interface for that. Used it the other day.
Posted By: calibro
Date Posted: December 18, 2006 at 8:13 AM
WOOOOOTTT
Look what I found.... https://stereophonik.com/gutterslide/IP-BUS_Hack/
May help any other pioneer users out there...
