Multi Dist. Blocks
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87616
Printed Date: May 11, 2026 at 2:00 AM
Topic: Multi Dist. Blocks
Posted By: jneal4k
Subject: Multi Dist. Blocks
Date Posted: December 21, 2006 at 11:46 PM
Hi !  Can someone tell me how many Dist. Blocks I will need to use..
I'm wiring  (1) JL 1000/1,with a cap, and (1) Xtant A4004 4 channel amp
 How many dist. blocks will I need for Power, and ground....and will I need (1) for remote turn-on also..?
                                                     -Thanks
Posted By: aznboi3644
Date Posted: December 22, 2006 at 12:14 AM
If you are using one 0 gauge or bigger power wire than you need one dist. block...a ground block is not necessary.
And the remote leads you can just daisy chain them.
DO NOT INSTALL THE CAP...read the sticky above about upgrading your big three...and do a search about capacitors if you wanna know what we think about them here
By the way welcome to the site
