1995 Honda Accord Stereo Wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=87762
Printed Date: May 10, 2026 at 7:00 PM
Topic: 1995 Honda Accord Stereo Wiring
Posted By: soccerguy4
Subject: 1995 Honda Accord Stereo Wiring
Date Posted: December 25, 2006 at 1:12 PM
So the deal is my 1995 Honda Accords stereo was jacked and all I have left is wires because they cut off the connector.  I found this website to tell me which wires were what on the car but I dont have all of them.  The only one I do not have is the blue/white wire (blue wire with a white stripe), and the one I do have is a WHITE/ yellow wire (white wire with a yellow stripe).  What do I do?  Do they go togther or ???  I know which ones are the consant 12V wire and the ground wire and the speaker wires but i dont know which wire is the switched wire which is the blue/white wire.  the thig is I do have two blue wires (one with a green stripe and the other with a yellow stripe) and they go to the speakers.
Also I have on my new stereo a blue wire which it says goes to the remote.  Does that hook up to anything or is it there to just catch the remote signal?
Date Posted: December 25, 2006 at 8:06 PM
oops i meant to say
"I know which ones are the switched  wire (which is the yellow wire with a red stripe) and the ground wire and the speaker wires but i dont know which wire is the constant 12V."
"I know which ones are the consant 12V wire and the ground wire and the speaker wires but i dont know which wire is the switched wire which is the blue/white wire."
So basicaly if I dont have a blue wire with a white stripe which one is it?  Is it the white wire with a yellow stripe?
Date Posted: December 25, 2006 at 9:22 PM
HAHA i keep messing up
I meant to say the first quote not the second
Posted By: geepherder
Date Posted: December 26, 2006 at 5:41 PM
Read the sticky "how to figure out stereo wiring", and use a meter to test the wires.
Posted By: 3cc_installer
Date Posted: December 30, 2006 at 5:00 AM
Right Rear Spkr (+) Red w/ Yellow Stripe
Left Rear Spkr (+) Blue w/ Yellow Stripe
Power Antenna Trigger Brown w/ White Stripe
+12 Volt Ignition Wire Yellow w/ Red Stripe
Right Rear Spkr (-) Brown w/ White Stripe
Left Rear Spkr (-) Gray w/ White Stripe
Ground Wire Black<>
+12 Volt Battery Wire White w/ Yellow or Blu Stripe
Dash Light Dimmer Wire
Left Front Spkr (+) Blue w/ Green Stripe
Right Front Spkr (+) Red w/ Green Stripe<>
Left Front Spkr (-) Gray w/ Black Stripe
Right Front Spkr (-) Brown w/ Black Stripe
Jared Nixon - A.K.A Jsmoke
3rd Coast Customs
Lake Charles, Louisiana
