blowing fuses on PPI a600.2
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=8888
Printed Date: May 06, 2026 at 9:36 PM
Topic: blowing fuses on PPI a600.2
Posted By: Big Blue
Subject: blowing fuses on PPI a600.2
Date Posted: January 31, 2003 at 3:11 PM
I have an older PPI a600.2 driving a JL Audio sub.  The amp just started blowing fuses at moderate to loud listening levels.  I have  a 120 amp fuse under the hood that goes to a fused dist block.  The  amplifer has a dedicated 50amp fuse at the dist block.  The cable is less then 10" and totally visible.  It is the only fuse blowing.    The onboard 60amp fuse on the amp does not blow.  Any Ideas?
Posted By: Big Purds
Date Posted: January 31, 2003 at 3:44 PM
bad ground or connection somewhere...something is touching something it shouldnt somewhere in that line...
