optimal box for kicker L715
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=88905
Printed Date: May 11, 2026 at 2:45 AM
Topic: optimal box for kicker L715
Posted By: wildchildbmx6
Subject: optimal box for kicker L715
Date Posted: January 14, 2007 at 8:46 AM
has anybody built a box for the kicker l7 that was optimal? i have 1 in a 5 cube ported box and it sounds ok, it trips on fast bass so im thinking of going smaller. any suggestions on size and type of box i should use
Posted By: dcblackbird
Date Posted: January 14, 2007 at 3:08 PM
well, what do you like listening to?
Posted By: 3cc_installer
Date Posted: January 14, 2007 at 6:53 PM
here is what the kicker tech bulliten says
compact ported enclosure - 3 cubic ft. per sub + port.  port = 2.5"x16.5"x19.5" long
reccomended enclosure (street bass) - 4.5 cubic ft. + port.  port = 3"x16.25"x14.75" long
SPL (Deep Bass) - 6.0 cubic ft + port.  port = 3.5"x16.25"x13.75" long
ported will be louder than sealed.
Jared Nixon - A.K.A Jsmoke
3rd Coast Customs
Lake Charles, Louisiana
Posted By: 90s civ and sub
Date Posted: January 15, 2007 at 7:07 AM
Call Kicker @ (405)624-8510,
Ask for tech support (These guys are the "mad scientists" for all that is Kicker).  Tell them what you have & what kind of sound you want.  They will give you specs for a monster!
I called them because I had an old Kicker F6.5C (6 1/2") freeair sub.  They gave me specs that were nowhere near what was on the tech bulletin.  How does it sound??  Put it this way, when I took it to car stereo shops to have installers listen to it, the closest anyone has come to guessing the correct size, was an installer who guessed "a ported 10".  I call it "The Tiny Avenger".
Remember, The recommended enclosure sizes in their bulletins are for good "all-around" performance, if you want something a little more over the top?  Contact them directly.  Hope this helps.
90 Civic DX Hatchback- 135 amp alternator
92 Suburban - 200 amp alternator
Stereo rebirth, coming soon. . . .
