05 and up Radios with no switched power
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=89443
Printed Date: May 16, 2026 at 12:17 PM
Topic: 05 and up Radios with no switched power
Posted By: sin0cide
Subject: 05 and up Radios with no switched power
Date Posted: January 23, 2007 at 7:48 PM
So I just worked on a 2007 honda civic and a 2006 dodge charger and both of the factory units did not have a switched power... which is fine if I was replaceing the stereo as I would just tap one but I have been putting more and more Motorola Bluetooth Handsfree units in cars without a mute wire... Which is fine if it has a switched power that I can relay. Anyone have the slightest idea on how they are controlling these radio's or how to shut them off without losing memory.. and also after removing the power from the dodge charger the radio still had presets... -_- how is that possible. I know I can relay the remote wire if the vehicle has a factory amp but what if it doesn't. I am sure someone has had to run into this issue before me.
Posted By: coppellstereo
Date Posted: January 23, 2007 at 10:28 PM
data-bus? can-bus?
Posted By: sin0cide
Date Posted: January 23, 2007 at 11:53 PM
Posted By: kgerry
Date Posted: January 24, 2007 at 5:03 PM
many newer vehicles use data for the radio.... switched power can be gotten at the ign switch or fusebox, or via a switching device like DEI's 55000.... which generates a switched voltage when seeing audio AC.......
------------- Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Posted By: BulletTooth
Date Posted: January 24, 2007 at 5:57 PM
Well a more painful approach would be to use relays at speaker outputs, which would cutoff the sound...not pretty but will work.
Date Posted: January 24, 2007 at 6:56 PM
thats how the parrot works. it interrupts the speaker input side and then passes the handsfree info
Posted By: sin0cide
Date Posted: January 24, 2007 at 7:36 PM
Well I am going to have to do some research of this data bus bull crap because I know there is a way I can make my own telephone mute circuit. there has to be a wire that sends that signal and something that can mimic it.
Posted By: throwback2332
Date Posted: January 25, 2007 at 1:37 AM
If the radio or headunit, sorry, has a mute button it can be done EASILY, no mute problem hope your good with diodes and relays.
------------- If it's not custom, then it's not you.
Posted By: a471789
Date Posted: January 25, 2007 at 10:01 PM
just as others have said, you can run a seperate accessory wire to a switched 12v+ at either the ignition harness or going into the fusebox. What could be easier than that? That's what I do for people that have a 2000+ GM vehichle that requres the GM09 harness, but aren't willing to fork over the cash. Just keep in mind that this very well may void the factory warranty despite the Magnusson-Moss warranty act. It changes the electrical configuration of the vehicle, as where using the right harness is just adding to it. ------------- Brent
MECP Advanced Installer
"I don't claim to know it all, just more than you."
Posted By: Silvrefox
Date Posted: January 25, 2007 at 10:40 PM
So I been watching you guys talk about how to fix it with radios that have no mute, but noone is sayin how. So can someone clue me in? Kinda new to the whole handsfree stuff.
Posted By: porschemaniac
Date Posted: January 28, 2007 at 8:21 AM
The "no mute wire" is no problem if you install a Parrot handsfree kit and a plug and play harness from these guys: www.parrotkits.com
