not ground noise something else.
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90029
Printed Date: May 10, 2026 at 1:18 PM
Topic: not ground noise something else.
Posted By: dkeshish
Subject: not ground noise something else.
Date Posted: February 04, 2007 at 12:12 AM
Hi guys, I own a pioneer avic n2, 2 power acoustik amps, one for a 2channel (for subs) one 4 channel for the speakers. Car is a 2006 chrysler 300. well a while back i had some serious ground noise issues that were solved by a member here with fuses and grounding to the case (damn pioneer). So now that is is solved there is a noise of a hummm more so. This is not ground noise I dont think because even when the car is in acc position the humm is still there. if i turn the gains all the way down it goes away but then no music.... Any help what could cause this and what would fix it?
Posted By: layinframe_95
Date Posted: February 04, 2007 at 12:17 AM
Are your interconnect cables running close to your amp power cables?  If one or the other isn't shielded well enough you can get a humming/buzzing noise that will increase with your volume...
Posted By: jettagli03
Date Posted: February 04, 2007 at 12:21 AM
You do know about Pioneer's rca problem right? If not, do a search.
Posted By: dkeshish
Date Posted: February 04, 2007 at 12:34 PM
hello thanks the wires are separated, and yeah i know the problems of the rca's with damn pioneer. The noise was a lot greater before the fix of grounding the rcas outer edge to the case. But this noise is almost like a fan hummm. Not sure what to do.
