06 murano, replacing bose system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90075
Printed Date: May 10, 2026 at 6:52 AM
Topic: 06 murano, replacing bose system
Posted By: armstrng90
Subject: 06 murano, replacing bose system
Date Posted: February 04, 2007 at 10:37 PM
when upgrading factory bose system-- can it b wired up2 excisting plug or do speakers need2 b rewired.any help on this car wud b gr8--thankyou
Posted By: macaholic
Date Posted: February 23, 2007 at 10:52 AM
I'm upgrading the OEM Bose system in my 06 Silverado with a JL Audio Cleansweep from the headunit to a JL 6-channel amp. replacing door speakers with 6.5" Polk componets. I'll let you know how it sounds in a couple of days.
Posted By: imseth85
Date Posted: March 03, 2007 at 12:47 AM
upgrading factory bose system? what do you mean by that...the only thing that can really be upgraded in a bose system is the head unit, nothing else can really be replaced by conventional means. Sometimes you can use the existing wiring, but you must alter it considerably. Tell us what it is you are upgrading exactly.
Seth Alvo     NY
Mobile Electronics Installer
Posted By: forbidden
Date Posted: March 03, 2007 at 5:49 AM
Murano is a peice of work. The factory cd MUST be retained. DO NOT REMOVE IT. After that a complete rewire for new speakers and amplfiiers. Audio Control, JL Audio, MTX and other companies all make interface adaptors that allow you to add whatever you like to the factory cd player.
