big system 2nd battery caps maybe
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=90894
Printed Date: April 19, 2026 at 12:07 PM
Topic: big system 2nd battery caps maybe
Posted By: ishv
Subject: big system 2nd battery caps maybe
Date Posted: February 23, 2007 at 8:04 PM
this is a very big system for me its a 96 two door tahoe im gettin the alt juiced up, 2 batt. one yellow top one duralast 1000 cold crankin amps, 2 ga power wire, efx pmbc200 isolator, 2 2fared power caps, im also upgrading all my wires under the hood to 2 ga, 2 merlin 200.2 (2000 rms at 1.5ohms i love this amp), 6 kicker comp cvr 15" (1 amp on 3 subs 2.67ohms runs perfect),all in a fiberglass box ill post up pics later i have the frame built. my questions are ....................................should i use the isolator or just run them parallel if so what size fuse or  circuit breaker should i use in between the batts. if i use the isolator im puttin the duralast in front jelly in the rear, now  im guessn i dont need the caps if i got both batts plus the alt juiced up right?plus where should i get a ground for the amps if the amps are more than 24" away from ne good ground should i weld a piece of metal from the frame up just to get a good ground?..........................
       im using the truck just to show off and to beat down the block with no power issues. its a 2 door tahoe gota do it big (but right)
----ISH----
I HATE RELAYS!!!!!!!!!!!!!
Posted By: haemphyst
Date Posted: February 23, 2007 at 8:20 PM
You have done nothing to address the SOURCE OF ALL ELECTRICAL POWER IN A CAR! The ALTERNATOR. Do not buy anything else, battery- or cap-wise, until you address your alternator.
Posted By: ishv
Date Posted: February 23, 2007 at 8:56 PM
the alt will be at 200 amp give or take its being tweaked  a lil
                                      LOL!!!
----ISH----
Posted By: forbidden
Date Posted: February 23, 2007 at 9:47 PM
Lose the caps altogether. Run identical batteries in parallel. Upgrade to 0 gauge power wire. Do the Big 3 or Big 4.
Posted By: coppellstereo
Date Posted: February 24, 2007 at 12:23 AM
i second that.
why cant you find a good ground? I never understood why this is such a hard thing to do
Posted By: ishv
Date Posted: February 24, 2007 at 12:37 AM
its not that its hard i usually mount my sub amps where ever looks good and run my ground to a good location even if it is 24" thanx for the input tho...........so run two jellies in parallel straight back to the amps no caps no isolator what size breaker 200 amp will do?
----ISH----
Posted By: aznboi3644
Date Posted: February 24, 2007 at 2:10 AM
There is steel everywhere in your truck that you can ground to...unless the amps are 2 feet above the floor than grounding shorter than that shouldn't be a problem
Date Posted: February 24, 2007 at 1:48 PM
Make sure to read the sticky topics at the top of this forum that are going to apply to your system. They are the what is a proper ground and how to upgrade the big 3.
Date Posted: February 24, 2007 at 6:30 PM
ive been around for a while .... but, what is a jelly?
you can ground to any sheet metal, not just where there is a pre-existing bolt.
Posted By: ishv
Date Posted: February 25, 2007 at 3:29 PM
my bad a jelly is our hood term for a gel cell battery.
----ISH----
