Converting 4 ohm speaker to 8 ohm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9122
Printed Date: May 07, 2026 at 7:22 PM
Topic: Converting 4 ohm speaker to 8 ohm
Posted By: raceman17
Subject: Converting 4 ohm speaker to 8 ohm
Date Posted: February 05, 2003 at 8:18 PM
Can I put a 4 ohm resistor in series on each 4 ohm speaker to make it an 8 ohm circuit?
Aaron
Aaron
Posted By: Derrik
Date Posted: February 05, 2003 at 8:44 PM
I dont think that's a good idea. you basically cut the voltage in 1/2. means you cut your watts in 1/2.
Why dont you tell us what you need to accomplish and maybe we can help. :)
Posted By: Derrik
Date Posted: February 05, 2003 at 9:05 PM
also..the speaker is 4 ohm impetance not resistance. so...by adding an 4 ohm resistance on will not make it 8 ohm impetance
Date Posted: February 05, 2003 at 9:25 PM
What if the speakers were bridged so I could have more watts?
Aaron
Posted By: Derrik
Date Posted: February 05, 2003 at 9:54 PM
usually the amp can put out more watts if your impetance is low. are you trying to  connect the speakers in series? so you can have 4ohm +4 ohm = 8ohm? I dont see what good that will do and the truth..i've never done that. I've connect speakers in parallel. which 1/4 + 1/4 = 1/x which = 2 ohm load which most amp that can handle 2 ohm load will put out more than 4 ohm.
Be more specific and detail of what you're doing. tell me about your amp. your speakers. etc
Date Posted: February 05, 2003 at 11:22 PM
The amp is a mtx pro75x2 here are its specs
RMS Power measured at 12.5 Volts DC:
37.5 watts x 2 into a 4 ohm load with less than 0.05% THD+N
75 watts x 2 into a 2 ohm load with less than 0.1% THD+N
150 watts bridged into a 4 ohm load with less than 0.1% THD+N
Dynamic Power (IHF-202 standard) measured at 14.4 Volts DC:
90 watts x 2 into a 4 ohm load
165 watts x 2 into a 2 ohm load
325 watts bridged into a 4 ohm load
The speakers are a 12" kenwood
Impedance: 4 ohms,  Power Handling: 700 Watts, and I think 175 watts rms
The head unit is a kenwood kdc-519
I'm new at this but, a buddy of mine made the suggestion since my speakers weren't 8 ohm.  And see, the amp will put out 325 watts bridged into a 4 ohm load.  So, if the speakers were connected in parallel and, in this particular case 1/8 +1/8=1/x   where,  x would equal the 4 ohm load which, my amp is designed for.  Like i said, I am new at this and I don't know.  It seems like it would work (in theory) if i could find a resistor to carry all the wattage but, any help would be appreciated.
Aaron
Aaron
Posted By: fakepete
Date Posted: February 06, 2003 at 7:45 AM
Your only impedance choices using those two subs together are 8 ohms or 2 ohms.  I would say either run them at  the 90w x 2 @ 4ohms or get a 2 ohm stable amp.
