2001 chevrolet blazer
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91290
Printed Date: March 27, 2026 at 11:58 PM
Topic: 2001 chevrolet blazer
Posted By: connerb
Subject: 2001 chevrolet blazer
Date Posted: March 05, 2007 at 12:05 PM
Does anyone have a 2001 Chevrolet Blazer wiring diagram or know where I can get one?
Posted By: master5
Date Posted: March 05, 2007 at 12:13 PM
here goes...
12volts  red   +   ignition harness
Starter  yellow   +   ignition harness
Second Starter  N/A
Ignition  pink   +   ignition harness
Second Ignition  white   +   ignition harness
Third Ignition  N/A
Accessory  orange   +   ignition harness
Power Lock  lt. blue   +   brown plug at BCM
Power Unlock  white   +   brown plug at BCM
Lock Motor  gray   5wi  driver kick panel
Unlock Motor  tan   5wi  driver kick panel
Parking Lights+  brown   +   lt. blue plug at BCM
Parking Lights-  white   -   lt. blue plug at BCM
This wire will not test when using the headlight switch. This wire is triggered by the DRL system. To meter the wire, start the car with the parking brake set, when the brake is released this wire will go to ground.
Door Trigger     -   BCM .Use tan for the drivers door located in pin B4 of the purple plug, orange for the passenger door located in pin B2 of the purple plug, and dk. blue/white for the rear doors and rear hatch located in pin B11 of the lt. blue plug, must diode isolate these wires.
Dome Supervision  use door trigger
Trunk/Hatch Pin  pink/black   -   lt. blue plug at BCM
Trunk/Hatch Release  black   -   purple plug at BCM
Factory Alarm Disarm  lt.green   -   purple plug at BCM
Notes: The BCM is located to the right of the accelerator pedal below the radio. The plugs on the BCM face towards the drivers side.
Tachometer  white   ac   PCM
The PCM is located on the passenger fender. On the 2.2L the wire is in a black 80 pin plug pin 10, and on the 4.3L the wire is in a red 32 pin plug pin 20.
Brake Wire  white   +   steering column
Parking Brake
Horn Trigger  black   -   steering column
Notes: Also found in the brown plug at the BCM on vehicles with a factory alarm.
Immobilizer Bypass  Required:  Passlock II
Posted By: kirktcashalini
Date Posted: March 05, 2007 at 2:05 PM
Oh damn, boookmarked (sure I will need this info sometime)... I am assuming this is the same for a 99... or damn close anyway? You the man Master5!
Posted By: the12volt
Date Posted: March 05, 2007 at 2:08 PM
...oO(this is the Car Audio Forum, how about the stereo wiring?)
posted_image the12volt • Support the12volt.com
Posted By: master5
Date Posted: March 05, 2007 at 2:32 PM
Yes it is audio..sorry I missed it..I don't usually get requests for GM audio wiring as either a harness is being use..and the fact that gm has had the same audio wiring for like 50 years..lol
Orange..constant
yellow....acc
black...ground
gray....ill
pink...remote if used
LF+ tan      LF-   gray
RF+ lt green     RF- dk green
LR+  brown   LR- yellow
RR+ dk blue   RR- lt blue
Hope I helped
Posted By: rudydapimp
Date Posted: March 05, 2007 at 2:47 PM
Orange - 12v constant
Yellow - 12v switched
Black - Ground
Grey - Illumination
Brown - dimmer
Tan Left +
Grey left -
Lt Green Right +
Dk Green Right -
Brown left rear +
Yellow left rear -
Dk Blue right rear +
Lt Blue right Rear -
