power acoustik amp and subs
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91307
Printed Date: March 28, 2026 at 6:23 AM
Topic: power acoustik amp and subs
Posted By: ratdog24
Subject: power acoustik amp and subs
Date Posted: March 05, 2007 at 8:19 PM
I have 2-12" 800w Power Acoustik Fubar 12-W subwoofers with dual-4 ohm voice coils and a Power Acoustik A2400DB Class D Amp rated at 900wattsx1@ 4 ohms RMS, 1400wattsx1@ 2 ohms RMS, or 2400wattsx1@ 1 ohm RMS. I am installing them in a sealed dual 12' Sub box.  I need to know what ohm rating I should run them at and how they should be wired-up(series, paralell)? I am new to all this and I am looking for good sound, not loudness. Thanks,Ratdog24
Posted By: aznboi3644
Date Posted: March 05, 2007 at 11:21 PM
use the woofer wiring link here
https://www.the12volt.com/caraudio/woofer_configurations.asp
If those subs are dual 2 ohm than wire them to the amp for a 2 ohm load...that amp will most likely fry at 1 ohm
