more power or keep it all the same?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91359
Printed Date: March 27, 2026 at 1:09 PM
Topic: more power or keep it all the same?
Posted By: jmelton86
Subject: more power or keep it all the same?
Date Posted: March 07, 2007 at 4:21 AM
I currently have a ClarionProAudio APA2104 hooked up to 4 speakers; a 6 1/2" and a 6x9" on each channel loading it at 2Ohms stereo. This amp claims 75wrms x 2 @ 2Ohms (12 volts, .08 THD). The amp in question is an Alpine MRV-F307. I would have to load it @ 4Ohms each of the channels. Tis' rated @ 30wrms x 4 @ 4Ohms (12 volts, .08 THD). Question is:
Is the 15 wrms per side from the Clarion better? I personally would rather have all Alpine above 80Hz (the Clarion is the only thing 'holding me back').
Also, the MRV-F307 has a small knob at the center of the circuit board on the inside, what is it?
Every comment is highly appreciated. jmelton86
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Posted By: haemphyst
Date Posted: March 07, 2007 at 10:23 AM
Well, your speakers are presently getting 37.5W each, in the listed configuration. You will realize a net loss of 7.5W per speaker - negligible in the extreme. However, with the 4 channel amp, you will gain four channel capabilities - i.e. fading, as well as balance (if desired)
Take a picture, and post it... As far as "what is this"? Who knows, especially with such a fantastic description as: "small knob at the center of the circuit board"... posted_image (kidding!)
Date Posted: March 07, 2007 at 5:44 PM
Yeah, I need to take some pics but I generally use my work pc. That's why I always post at night, 3rd shift. -But that's no excuse! Maybe this weekend...
-The Alpine would be getting more input voltage, 4 channel in instead of 2. Would this give me significant signal quality?
BTW i'm getting the MRV-F307 for installing a HU for a friend... in an S10.
Thanx for input
Big3 in 1/0G
1/0G to GTO14001
Date Posted: March 07, 2007 at 5:48 PM
Awesome, you can't call me a rookie anymore. lOl
Big3 in 1/0G
1/0G to GTO14001
Date Posted: March 08, 2007 at 8:30 AM
No. Why are you thinking that? Same deck, right? Then the same signal strength. Nothing is going to change, and you'll still need to set your gains accordingly.
Date Posted: March 09, 2007 at 11:30 AM
Same HU, I just figured the 4 ch. amp (Alpine) would have a cleaner signal then the 2 ch. (Clarion) cause it's getting 4 (5v max) inputs instead of 2. This isn't right? I just thought it made sense...posted_image
Big3 in 1/0G
1/0G to GTO14001
