wiring 4 ohm and 2 ohm together
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91365
Printed Date: March 27, 2026 at 8:05 AM
Topic: wiring 4 ohm and 2 ohm together
Posted By: dalfe5
Subject: wiring 4 ohm and 2 ohm together
Date Posted: March 07, 2007 at 10:23 AM
I have a set of 2ohm components and a set of 4ohm two-ways. I want to use the 2ohm for the front and the 4ohm for the rear off of one amp. I want to wire it up with the lt front and rear together and the rt front an rear together. Does anyone see a problem with this?
Posted By: haemphyst
Date Posted: March 07, 2007 at 12:47 PM
Yes. 4 ohms in parallel with 2 ohms is probably too low an impedance for your amplifier. Unless it says SPECIFICALLY that it is safe running at a load of less than 2 ohms, you will be asking for trouble.
Posted By: dalfe5
Date Posted: March 07, 2007 at 1:24 PM
I was gonna wire it up in series based on this wiring schematic Decware / High Fidelity Engineering Co.. I am using this now but with both set of speakers being 4ohm. Sound great to me but want to use the new Infintys I have. I know you can't actually see the schematic but it tells about it in the artical. I have the actual schematic to go by.    As for my sub I am using theDeathbox with a Kicker 10L7 powered by two channels bridged on a Kicker KX850.4 at 4ohms. The frt/rear speakers are powered by the other two channels. Please let me know what you think.
Posted By: stevdart
Date Posted: March 07, 2007 at 6:15 PM
Sure, series wiring would be fine.  The amplifier will output into a 6 ohm load, and the front 2 ohm components will receive twice the power as the rears.
Run positive from the amp up to the front's crossover pos input.  From the xover neg input, run a wire to the rear speaker's pos terminal.  Then run a wire from that speaker's neg terminal back to amp neg.
Posted By: frydchkn
Date Posted: March 09, 2007 at 12:40 AM
All I have to say is "4-Channel".  You'll know what I'm talkin about when you get one.
Posted By: dalfe5
Date Posted: March 09, 2007 at 10:51 AM
I have the amps to go that route but I want to go with just one amp for now. I have 2 Kicker KX350.2 and one KX850.4. I am using the 850.4 now. Two channels for the frt/rear and two channels bridged for the DB. When time//health permit I am going to build another DB and use one 350.2 for the fronts and one for the rears and the 850.4 to drive the two DBs.
Posted By: frydchkn
Date Posted: March 10, 2007 at 1:34 PM
Dalfe5,
You don't mow an acre with a push mower, when u have a john deere ride-on sitting in the garage.  You have a complete system that is pretty much matched up.  Why are you trying to manage with less components?  Its less work, not to mention less risky, to just throw both amps in at the same time, without worrying about managing connections, if or will it work? how well? how loud? how long?
I'm not trying to discourage you from reaching your goal, which at the far end I would imagine is great sound.  I would just hate to see you deprive yourself of what your amps can give you and with the same or maybe less effort than how you are trying to get it done.
Posted By: dalfe5
Date Posted: March 12, 2007 at 10:03 AM
Like I said in my last post, "When TIME / HEALTH permit" I will use the remainder of my equipment. As for as the lawnmower goes is if I had to work on the John Deer but was unable to do it before time to mow the grass I would use the push mower. In order for me to use the rest of my equipment I would have to do more than just hook it all up.    I would have to buld somewhere to mount the amps and crossover plus run new wiring. Thanks for everyones help.
Posted By: frydchkn
Date Posted: March 12, 2007 at 11:49 AM
It is what it is, and to each their own...good luck.
