cd player, no harness in truck
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91689
Printed Date: March 26, 2026 at 5:58 PM
Topic: cd player, no harness in truck
Posted By: turtles1118
Subject: cd player, no harness in truck
Date Posted: March 13, 2007 at 10:06 PM
what do i do? ive installed a few cd players but this truck caught me off guard. picked it up last week and got it home with no radio in it, just a big hole in the dash. got to looking for a harness but couldnt find one, tore a part the dash, still nothing. Ive got my speaker wire, ground, constant power wires ran but what do i do with the wire that is supposed to connect to the ignition. I tried to conect it to the batt. with a switch but keep pooping the fuse. What to do?, What to do?
Any help please.
Posted By: ajzautoextreme
Date Posted: March 13, 2007 at 11:25 PM
you can always go to the fuse box and find a switched sourced from there just an idea. Bty  what year truck?
Posted By: jmelton86
Date Posted: March 13, 2007 at 11:38 PM
You have the right idea. The fuse keeps popping either b/c it's way too small or the wire you ran is shorting out somewhere... What size wire did you use?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
Date Posted: March 13, 2007 at 11:41 PM
...Also, what size fuse did you use? Head units usually have a 10a fuse in the back, sometimes 15 (offbrands, Jensens do) so if your HU has a 10a fuse in the back then use a 15a fuse in the power wire. If your HU has a 15a, use a 20a.
Big3 in 1/0G
1/0G to GTO14001
Date Posted: March 14, 2007 at 7:46 AM
1987 Isuzu pup, singal cab. #10 fuse in the radio and 18g for the speakers and 12g for ground and power.
Posted By: rich45
Date Posted: March 14, 2007 at 9:36 PM
wats going on. you do have the right idea. but just make your life easy get the same guage wire as the speaker wire, go to the ignition harness test for accessary with your meter and tap into that wire and connect it to the red wire on the radio harness which is switched 12 volts. This way u dont have to fuse any other wires exept constant. It is safer then going to the fuse box and risking shorting something else out.
signing off rich45
