2005 corvette, amp, sub w/bose system
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=91835
Printed Date: March 30, 2026 at 10:57 PM
Topic: 2005 corvette, amp, sub w/bose system
Posted By: mistahiggs
Subject: 2005 corvette, amp, sub w/bose system
Date Posted: March 18, 2007 at 12:41 PM
Just installed a jl audio stealth box in a 2005 vette with the bose system.  I used the locb.2 from soundgate to pick up the audio signal between the radio and the bose amp.  When the factory radio is off and the car is running there is a flutter in the sub.   I've checked everything that i can think of and i can't fix the problem.  I'm also assuming that i would need a gmacc piece to get an amp turn signal when the car is not running?  any help would be appreciated...
Posted By: Velocity Motors
Date Posted: March 18, 2007 at 3:35 PM
Ensure that yout ground is good ( free of paint, grase, dirt ). For the amplifier turn on , just use the switched ignition source from the fuse panel or at the ignition column ( PINK ).
