15 kicker l7 dual 2 ohm
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92165
Printed Date: May 10, 2026 at 3:21 AM
Topic: 15 kicker l7 dual 2 ohm
Posted By: jeffliberty
Subject: 15 kicker l7 dual 2 ohm
Date Posted: March 26, 2007 at 10:24 PM
Hi i have a 15" kicker L7 dual 2 ohm sub and i want to put it in my dodge dakota quad cab the biggest i can go in measurments are 33 inches wide 22 inches deep 21 inches in height i want a ported box i listen to alot of rap music and bass cds i was just wondering what the best box is for me to use for this sub i want it to rumble like hell and i also want to feel the bass all through my body basically i want to be heard and felt lol can you please help me with specs and dimensions with port size and lengths i have had bad luck building boxes for subs so please be as informative as possible without going into terms that the normal person wouldnt understand
thanks
------------- 1998 VW GTI VR6 5 Speed manual, JVC kd-nx5000 plus 7 inch indash screen optima batteries Eclipse 7122 mono sub amp which im still having serious problems with, and a 12 inch Orion sub
Posted By: coppellstereo
Date Posted: March 26, 2007 at 11:40 PM
i would start by getting the woofers technical specs from kicker.com do you not have your owner's manual I know this woofer has a massive ported box where do you plan to install this box in your truck are you comfortable making a complex box for this install why dont you use punctuation
Date Posted: March 26, 2007 at 11:53 PM
lol sorry its going to be inside the truck behind the drivers seat im taking one of the seats out of the back
here are some specs
spl db 1w/1m 89
displacement cc: 4530
displacement cu in:276.5
revc: 3.56
vc inductance mH: 3.98
sd m3: 0.1056
bl: 21.395
vas litres: 179.3
vas cu ft: 6.33
moving mass Oz: 1273
fs 24.2
qms 6.8965
qes 0.4515
qts 0.424
xmax 16.1
those are the specs in the manual
let me know if you need more info
i have no problem when it comes to building the box cause im a cabinetmaker but its just to findout the perfect specs to build one
Date Posted: March 27, 2007 at 9:41 AM
here is a link to the box parameters for the L7
https://www.kicker.com/06/tech-support/manuals/manuals/2006/2006%20L7%20Sub%20b01%20WEB.pdf
it tells you the smallest ported enclosure (3.0 cuft) and the maximum (6.0 cuft)
