amps shutting off?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=92588
Printed Date: April 01, 2026 at 7:25 PM
Topic: amps shutting off?
Posted By: scotth86
Subject: amps shutting off?
Date Posted: April 05, 2007 at 9:27 PM
Here's the problem, i have a Sony CDX-CA810 head unit hooked to a Rockford amp on the subs, and an Alpine 360 watt amp on the highs. Everything works great, until you try to listen to a CD, then both amps shut off. The radio works fine, both amps on, powering everything like they should. Im thinking its the remote, i used to blue Remote wire coming off the headunit. i just took the headunit and rockford amp out of another car and they worked fine. Any ideas????
Posted By: the12volt
Date Posted: April 05, 2007 at 9:29 PM
Use the blue/white wire instead of the blue wire from the head unit. ------------- the12volt • Support the12volt.com
Posted By: scotth86
Date Posted: April 05, 2007 at 10:07 PM
ok, i'll try that. But why would using the blue wire intended as the remote wire cause the amps to shut off when i switch it to CD?? It makes no sense to me.
Date Posted: April 05, 2007 at 10:10 PM
The blue wire is the remote lead for a power antenna and only has 12 volts when the tuner is on. The blue/white is the amplifier remote turn on lead. ------------- the12volt • Support the12volt.com
Posted By: scotth86
Date Posted: April 06, 2007 at 10:10 AM
Ahh, i see. thank you very much. i appreciate it.
Date Posted: April 06, 2007 at 10:13 AM
You're welcome ;) ------------- the12volt • Support the12volt.com
