2000 porsche boxster radio wiring
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93228
Printed Date: April 08, 2026 at 9:55 AM
Topic: 2000 porsche boxster radio wiring
Posted By: 410440
Subject: 2000 porsche boxster radio wiring
Date Posted: April 22, 2007 at 3:51 PM
Any one have this information available?
I have a 2000 Boxster (NON S) here that we are trying to put a double din into and need some wiring information.
Thanks.
------------- Matthew Robertson
Senior Installer
Best Buy Deerfoot Meadows
Calgary, AB, Canada
Posted By: KarTuneMan
Date Posted: April 29, 2007 at 1:00 AM
Good Luck | 12V DC Battery(Constant) | RED / black | | D8 | 15 Amp | Fuse holder D | | Switched Accessory | Orange | | E1 | 7.5 Amp | Fuse holder E | | Ground | Brown | | | Power Antenna | White | | | Remote Turn On(output) | BLACK/ red | | | Illumination | Gray/blue | | | Mute | Yellow/black | Telephone mute | | Left Front + | GREEN/ red | Line level output | | Left Front - | NCA | Pin C1-3 This common ground splits up at the amplifier where left front is BROWN / green. | | Right Front + | Violet/red | Line level output | | Right Front - | NCA | Pin C1-3 This common ground splits up at the amplifier where right front is BROWN / violet. | | Left Rear + | Yellow/red | Line level output | | Left Rear - | NCA | Pin C1-3 This common ground splits up at the amplifier where left rear is BROWN / yellow. | | Right Rear + | RED / blue | Line level output | | Right Rear - | NCA | Pin C1-3 This common ground splits up at the amplifier where right rear is BROWN / blue. |
AMPLIFIER OUTPUTS | |
| Wire Function | Color | Note | Fuse # | Size | Location | | 12V DC Battery | RED / blue | | D9 | 15 Amp | Fuse holder D | | Remote Turn On (input) | BLACK/ red | | | Left Front Mid + | Green | | | Left Front Mid - | BROWN / green | | | Left Front Tweeter + | Yellow | In-panel speaker | | Left Front Tweeter - | Yellow/brown | In-panel speaker | | Right Front Mid + | Violet | | | Right Front Mid - | BROWN / violet | | | Right Front Tweeter + | Red | In-panel speaker | | Right Front Tweeter - | RED / brown | In-panel speaker | | Left Rear Mid + | White | | | Left Rear Mid - | BROWN / white | | | Right Rear Mid + | Blue | | | Right Rear Mid - | BROWN / blue | |
AT SPEAKERS | |
| Wire Function | Color | Note | | Right Front Mid + | Green | | | Right Front Mid - | BROWN / green | |
