what amp for these subs?
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=93790
Printed Date: April 09, 2026 at 8:09 PM
Topic: what amp for these subs?
Posted By: craigpiper
Subject: what amp for these subs?
Date Posted: May 10, 2007 at 4:44 PM
Hi guys,
i'm really sorry to ask this question and i know there are lots of other posts out there that explain how to work this out, but i am confussed?!?!?!?!?
I have two "AUDIOBAHN PERFORMER AWC12T" and
Fs  31.4 Hz
Qts  0.59
Qes  0.71
Qms 3.57
Vas (Liters) 69 Liters
Vas (Cu. Ft.) 2.45 Cu.Ft.
Re 3.3 ohms
Le 1.5 mH
Mmd 130 grams
Xmax +/- 8mm
RMS 500 Watts
Sd 0.051 M2
Freq. Resp. 25Hz-800Hz
Efficiency 92.9 dB
please, please help!!!!
thankyou!
Posted By: aznboi3644
Date Posted: May 10, 2007 at 5:15 PM
how much money do you want to spend?? What coil configuration and impedance are those subs??
Date Posted: May 11, 2007 at 2:17 AM
i dont want to spend more than $500 and i want them to sound as good as they can (i know there not the best subs in the world)
there 4ohm coils, not sure on the impedance so here is the link to the subs and the teck is on the bottome om the page. https://www.audiobahn.com/Audiobahn06/pages/woofers.html
Posted By: DYohn
Date Posted: May 11, 2007 at 8:29 AM
You have two of them?  Then you will probably get best performance wiring them for 2-ohms each (voice coils in parallel) and putting the two woofers in series for a net 4-ohm load, and then purchasing a mono subwoofer amplifier for them.  But the real next question is what sort of enclosure are you planning?
Posted By: haemphyst
Date Posted: May 11, 2007 at 10:22 PM
Ummm... Audiobahn? The BEST amp for them is the wall socket. (In Great Britain, you oughta be able to make some AWESOME sparks, with 240 volts!) Blow those things up, take 'em back to the store where you bought 'em, get a store credit, and buy a real woofer... (yes, I said a woofer, any decent SINGLE woofer will far outperform those boat anchors!) Something with a few less flames, and a whole LOT less chrome...
Sorry, that wasn't very helpful, was it? posted_image
Date Posted: May 12, 2007 at 5:28 PM
haemphyst, thanks for the construstive comments, but not everyone makes a choice knowing everything about everything and some people even have a budget!!!!!!!
What would you sujest then???
Date Posted: May 13, 2007 at 1:13 AM
If you want a budget amp.
https://www.online/CarAudio/ProductDetail.aspx?Productid=16696
If you want a good amp that will stroke those really quick
https://www.edesignaudio.com/edv2/product_info.php?cPath=21&products_id=44
I only suggest the ED amp because I have one and it is a beast. Some people on here may say ED sucks...well that was a few years ago and they had some problems. Now everything is good and very good quality. 5 year warranty also. And they pay for shipping whatever broke back to them for them to fix or replace.
