Colt 1988 Wiring Diagram
URL: https://www.the12volt.com/installbay/forum_posts.asp?tid=9385
Printed Date: May 07, 2026 at 11:17 AM
Topic: Colt 1988 Wiring Diagram
Posted By: mingolla
Subject: Colt 1988 Wiring Diagram
Date Posted: February 11, 2003 at 3:48 PM
Hi!
I need a carstereo wiring diagram for a 1988 M. Colt.
Can anybody help?
Posted By: bigbadconrad
Date Posted: February 11, 2003 at 8:44 PM
you should be able to find it on this site, under the vehicle database section, the colt has two harnesses that you need to tap into, one for negitive speaker terminals and the other for the rest of the stuff., I used to own one, so lemme know if you need help
what's up dude's, its Vancouver's finest.... the big bad conrad
Posted By: mingolla
Date Posted: February 13, 2003 at 10:44 AM
Hey! Thanks for Your reply. The Colt 1988 isn't listed, but mostly all other Mitsu cars. My problem is the ground wire - can't figure out which one it is? The stereo only works when I plug in the antenna cable, and that is not a good solution... I've even bought a "transformer" cable to change the old Mitsu cable "box" into ISO. Got any more suggestions - or perhaps know where I can find a diagram on the internet?
Thanks again, Alex.
